Question about Hotpoint HSS25GFP Side by Side Refrigerator
Freezer has frost on the back wall refrigerator does not cool very well
  • 58 Answers
Ref is not defrosting, prob a def control issue
Posted on Mar 12, 2008
Frost build up in freezer
You need a new bimetal fuse for your defrost cycle in your freezer.
Feb 28, 2014 | Hotpoint HSS25GFP Side by Side...
Freezer is cold but refrigerator side is barely cooling. turned off and water leaking out of door on the freezer side
Hello Roxanne,
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up,i would take off the back wall of the freezer and replace the deforst heater and defrost termination. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead in the fresh food compartment in the control panel where the thermostat is. I would replace heater/defrost termination first though since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Maytag MZD2766GES Side by Side...
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
GE refrigerator model PSS27MGMBB Freezer is not working
Open the freezer door and look at the back wall. If there is frost on the back wall, you have a defrost problem, which means air cannot circulate over the cooling coils located behind the freezers back wall. You will have to remove the back wall and melt all the frost with a hair blower, then replace the defrost heater. (part number WR51X10055) . This is assuming that the fan by the compressor and the one inside the freezer are working.
Jul 01, 2009 | GE PSS27MGM Side by Side Refrigerator
No cooling
Both refrigerator and freezer operate from one system. Air from freezer cools refrigerator. Check back wall of freezer for frost buildup. If frost is evident on the back wall of the freezer it indicates a defrost system problem.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
The refrigerator is not getting cold to it's recommended settings.
Check for a frozen coil in the freezer. Air from the freezer supplies the cold air to the refrigerator section for cooling. If frost is on the back wall of the freezer section you have a defrost system problem.
Frost on the back wall of the freezer indicates timer or heater circuit failure.
Jun 10, 2008 | Whirlpool Refrigerators
The fridge section of my LG GRB218JUDA has stopped working and the temperature indicator reads Err FF. Can you help
Side by side and other refrigerators are controlled or cooled by one system. Look to the freezer side for frost buildup on the back wall of the freezer. Frost buildup on the back wall of the freezer stops the air that cools the refrigerator from circulating. Frost on the back wall indicates a problem in the defrost circuit related to the timing device, heaters or defrost thermostat.
Jun 02, 2008 | LG Refrigerators
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
49 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
