Pings-no-pongs I attempt to ping a dvice that is attached directly to the router and it fails? It's my Xbox360...
  • 35 Answers
Well, try to check if you configure your xbox360 properly, if it is correctly configure, well better check the cable which you used to connect your xbox360 and your router.
Posted on Mar 12, 2008
SOURCE:
How do i enable icmp on linksys E1200 router?
You can't "open" ICMP. Necessary ICMP messages are automatically forwarded.
All you can do in the router is to "Filter Anonymous Internet Requests". If you set this option the router won't answer to pings. If you disable this option the router will answer to pings.
But again: this is the router responding. It has nothing to do with port forwardings.
Apr 23, 2015 | Cisco Linksys E1200 Wireless-N Router -...
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP Internet Connection Type Select Static IP to begin configuration of the Static IP connection. Account Name Leave Blank Domain Name Leave Blank MTU Auto IP Address ie: 192.168.1.100 (assigned IP Address) IP Subnet Mask Specify the subnet mask of your Xfinity Router Gateway IP Address Specify the gateway of your Xfinity Router Primary DNS Specify the primary DNS server's IP address of your Xfinity Router Secondary DNS Specify the secondary DNS server's IP address of your Xfinity Router Discard Ping on WAN Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers. Accept / Cancel Click Accept to confirm the changes or Cancel to cancel and return previous settings. Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load Hope that this help you.
Sep 10, 2014 | EnGenius ECB350 Wireless-N Indoor...
How much does a ping pong ball normally cost?
A high quality (3 stars) ping pong ball costs around $1. These balls last for along time. Cheaper, low quality ping pong balls can be purchases for much less,but they will not last you a long time.
Aug 05, 2012 | Sport & Outdoor - Others
How do I properly clean my ping pong table?
Cleaning your ping pong table may be a daunting task, but a worthwhile one in my opinion. I found you a great 5-step guide to having your tables clean in no time.
http://www.livestrong.com/article/180843-how-to-clean-a-ping-pong-table/
Jul 29, 2012 | Sport & Outdoor - Others
I would like to attempt to build my own ping pong table for our home. Can anyone send me a guide that will help me with this project?
In my opinion, you may want to rethink this strategy. Although building the table yourself will be less costly and provide you with satisfaction, it is not a good idea. In my opinion, even the cheapest made tables on the market may cost similar to what you would spend on materials and will still be constructed better (no offense). Ping pong tables are very difficult to construct properly and require a lot of skilled work. However, if you are still set on building one yourself, I will provide you with a few links that may be helpful.
http://www.essortment.com/table-tennis-build-ping-pong-table-scratch-49822.html
http://www.instructables.com/id/How-to-Build-a-Ping-Pong-Table/
I have never changed the rubbers on my ping pong paddles and have been using them for just over a year. I bought some new rubbers, but don't know how to change it. Can someone please help me?
Changing the rubbers of a ping pong paddle can take between 15-20 minutes of your time and a lot of precision. I will send you a how-to guide that will take you through the steps.
http://www.ehow.com/how_5672496_change-ping-pong-rubber.html
How to assemble a sportcraft ping pong table
Need direction to put together sport craft tt5000. Lost them
Jan 07, 2010 | Kettler Stockholm Indoor Table Tennis Ping...
My computer says I have an excellent signal, but then I am not able to connect to the Internet. Please help!
You're connected to the router itself, but is the router connected to internet?!
ping out 208.67.222.222 (OpenDNS) and check it.
If it pings, you've something wrong in DNS
if it don't, enter in the router management page and check internet status.
Sep 14, 2009 | Linksys Wireless-G WRT54G Router
My zoom x6 modem doesn't block pings (ICMP). How do I configure?
Blocking ICMP pings on a Zoom requires a few steps:
1) Go to Advanced Setup and select Advanced Firewall Filter.
2) Enable Advanced Firewall Filter.
3) Click on Security Policy Configuration.
4) Click on Policy Rules for "Add Firewall External-Internal Filter Rules."
5) Click on Add Policy Rule.
6) In the row labeled "Protocol," select "neq" and enter ICMP where it says "(Protocol Number or Name)."
7) In the row labeled "Select the direction to filter packets," select BOTH.
8) In the row labeled "Filter Action," select DENY.
9) Click on Save Changes and repeat 1) through 5).
10) In the row labeled "Protocol," select "eq" and "TCP." Below, select BOTH for direction, and ALLOW for filter action.
11) Save changes and repeat 1) through 5).
12) In the row labeled "Protocol," select "eq" and "UDP." Below, select BOTH for direction, and ALLOW for filter action.
13) Save changes.
14) Go back to Basic Setup and save changes to Flash.
That's it. Good luck!
Jan 26, 2009 | Zoom X6 (5590) DSL Modem (55900003)
I cannot get online using the web browser to the wrt54gx router. I can't ping it either. My laptop will ping things on our network. I reset the router to factory default but cannot ping the 192.168.1.1
ok connect the router to the system troug a ethernet cable and ping 192.168.1.1 if it pings ,try to ping www.google.com,if it will show you four reply,use the commant ipconfig /release then ipconfig /renew now turn off the router and turn off ur cable modem and now turn off your computer .Restart the computer ,turn on the cable modem and then turn on your router now try to go inline
May 25, 2008 | Computers & Internet
Open Questions:
Roadrunner Email Number#{1-855*536*5666*}Roadrunner Email tech support phone number Roadrunner Email is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Roadrunner Email email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Roadrunner Email support number When you are using the Roadrunner Email for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Roadrunner Email support number and ask for the help. Once you dial the Roadrunner Email customer support number, you come in contact with a team of experts at the Roadrunner Email customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Roadrunner Email support phone number will help you with that simply and quickly. This is Roadrunner Email's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Roadrunner Email agent. Features of Roadrunner Email support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Roadrunner Email customer support phone number. Here are some of the features of customer service: The Roadrunner Email customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Roadrunner Email customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Roadrunner Email provides you the facility of Roadrunner Email support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Roadrunner Email. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Roadrunner Email Customer support number team.
Oct 18, 2019 | HIS Computers & Internet
Computers & Internet Logo
47 people viewed this question
Ekse
Alun Cox
