Question about RCA P52830BL 52" Rear Projection Television
P52754at when on button is pressed tv try to come on sounds like a relay clicking in back of unit green light on button comess on and off a few times then tv shuts off! is this an easy fix? can it be repaired for less than what a new unit would cost and what is it that is wrong?
  • 61 Answers
Sounds like the block has shorted,not sure if you can replace your self but part number is 205064,you have to remove the grill were the speakers are and behind the grill is a panel,removing this panel and there is a part between the left and middle tube with a bunch of red wires on it ,this is what i think is bad.
Posted on Apr 01, 2008
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
RCA P52754AT POPPING SOUNDS. COLOR FLICKERS AND
It sounds like your high voltage block is arcing and causing the TV to go into protection shutdown temporarily. If that's the case, you'll most likely need to replace that HVB.
The other thing it could be if you're hearing "popping" (snapping ?), is that one of the CRTs could be arcing to ground, maybe the green one since you're getting too much green.
Good luck.
Nov 28, 2009 | RCA P52771AT 52" Rear Projection...
Green power light on but no sound or picture.
When I press the power button it just clicks.... what. ... vs-60603 I will only stay on for a few seconds and then shuts off. ...
Mar 30, 2009 | Mitsubishi VS-45502 45" TV
Another dead Vizio... P50HDM
95% Y and Z sustainer boards since you alweady had red pixels.
May 15, 2008 | V, Inc. Vizio P50HD Plasma Television
RCA P52754AT rear projection tv won't turn on
Good way to test for bad buttons is go inside the back and there is a black multi-wire cable that is connected "front and center" of the center lens on top of the chassis....easy to get to from the back.
Disconnect it....
I've had touchy switches on this unit that cause the problems you're seeing....and who uses the switches? Your remote will still function, and with the buttons disconnected, the microprocessor won't get stuck servicing a false command....which by the way makes it IGNORE the remote when they go goofy on you..... Source(s): Over 24 years servicing TV sets......
Feb 11, 2008 | Televison & Video
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Televison & Video Logo
134 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
