Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Hi...got ur message
Im using the router both for the wired and wireless features. wat is wimax?
  • 818 Answers
Wixmax is a new tecnolgy that will be implement a the end of this year o the start of 2009, this tecnology permitted to high speed conection with wireless seems at 74 mbit with long distance of 50 km. the new o this tecnology is that his better of wifi because have the capacity to Overcome the obstacle, that wifi can be difficult it, for more information
see this
www.wimaxforum.org
here is a lot of information, hope that this can helpful for you.
Sergio
Posted on Mar 12, 2008
SOURCE:
I can't get my Belkin G Wireless router to work with my Clear WiMax modem even after keying in the security key..is this router compatible with this modem?
Any router should work with any modem. Make sure you are running an ethernet cable from the WAN/Uplink port of the router to the modem, or in some cases it will be a USB cable. Also you can test your internet connection by plugging a computer directly into the modem.
Apr 04, 2012 | Belkin Computers & Internet
Low signel strength
Common with single antenna routers and adsl/router boxes, i use a zoom x6 adsl with wireless and i was having similar problems , it also has a single antenna so i disabled its wireless feature and got a linksys rangebooster router dedicated to my wireless needs, has good range and its durable, Im basically suggesting that you get another wireless router with dual antennae and use that for your wireless needs, hook that up to your DLINK modem via ethernet cable and disable the dlink's wireless feature...Hope this helps..
Oct 27, 2010 | D-Link DSL-G604T Wireless Router
No wireless light, and no wireless signal detected
there is a possibilty that wirelss feature on ur router is not turned on as the wireless light is off.
U can open the gui(router page) of ur router by entering the default gateway on the browser address bar. First of all u would need to connect ur comp using the cable to ur router so that it could be connected to internet.
Go to command prompt and type ipconfig and press enter and it will give u the ip and default gateway of ur router.
U can type the same default gateway in the address bar of internet exploere and hit enter and it shud bring the router page.
Once u r on the router page u can check the wireless settings on to that and can alter them.
Jun 07, 2010 | Belkin Wireless-N Wireless Router with...
Im trying to setup a second pc to my wireless router linksys wireless-G wrt54G it tells me to go to www.linksysfix.com/ela but its no longer available how do i connect my 2nd pc now?
Hi John
I'm not sure why you are being directed to that website. Connecting a second pc is just the same as connecting the first - nothing special is involved unless the router has been set up with access lists.
What is preventing the second pc from connecting? What sort of message are you getting when you try to connect?
Sep 26, 2009 | Linksys Wireless-G WRT54G Router
I have 2 laptop computers with built in wireless and I am trying to connect to internet via a D-Link 615. I have tried multiple things but it keeps telling me that my cable is disconnected and I have no...
HI. you have to check first what kid of modem u have.. im sure if the laptop is connected directly to the modem, u have a wired connection and u can connect to the internet.. if ur modem is a cable modem, u need to mac clone the mac address of the computer that can connect to the internet. u need to connect the computer that can connect to the internet to the router and do a mac clone and the internet connection settings is dhcp..if u are using a username and password to connect to the internet, u need to use the pppoe settings on the router, and if ur isp give u a static ip address, u need to set the router on static ip. how u can check the ip address, click on start, run and type cmd and it will show a dos prompt, type ipconfig/all and it will list the ip address, subnetmask, default gateway and dns server.. u need to setup the router first in order to talk to ur modem..
Jul 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
SRX200 Im using Wimax internet, my router is connected to entranet. cant get connec with my laptop
Linksys wirelss G router has many issues.
It isn't compatible with many adapters. You are constantly resetting.
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
I have Wimax wireless internet and I connected a router with the wimax and it functions well.I connected a 2nd computer to the internet picking up the signal from the router.The problem is,the network...
You can the CD that came along with the Wimax, if there is. it will teach you how.
If not, you can look for the IP in the manual which you will encode in the address of your browser so you can enter the Wimax configuration.
There you will find options on how to have security on you router.
If there is a manual it will help you a lot on how to configure it.
Apr 03, 2009 | Encore ENHWI-G-RLAM 4-Port Wireless-G...
Configuring DLink Wifi router for Reliance broadband
quick questions
1. how did you setup your modem?..is it via PPPoA or PPPoE
2. can you please provide the model number of your modem
thanks
Apr 24, 2008 | Linksys Wireless-G Broadband Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
41 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
