Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Subzero 611 Refrigerator not cooling, freezer fine
I have a model 611 Subzero (made 11/02) that the refrigerator only cools to 55 degrees; the compressor for the refrigerator runs continuously, but that's all that happens. The freezer works fine. I have checked all the refrigeration system for leaks (with a leak detector and a spray to see if I can find any bubbles) but nothing showed up. With the back panel inside the fridge removed and close to the evaporator coil I can hear a slight hiss coming from the coil (not a leak). Any suggestions? Thanks in advance!
  • cck773 Mar 29, 2009
    same thing. refrigerator not cooling.
  • barb_greg200 Apr 30, 2009
    Freezer works properly, fridge is too warm. Coils are clean.
  • 26 Answers
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Posted on Mar 31, 2008
  • luckydawg65
    luckydawg65 Aug 06, 2012
    Same problem. Called Subzero, no charge for parts and I'm past the 12 years! Glad I found this site.
Freezer freezes, but refrigerator section will no get beow 55 degrees.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 06, 2011 | Whirlpool ET1FHTXM Top Freezer...
My Hotpoint HSS25IFMD fridge quit cooling on the refrig side. It stays at 55 degrees. The freezer works just fine. Any thoughts?
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Dec 27, 2010 | Refrigerators
Our Freezer gets super cold but the fridge is 55 degrees. the inside air vents clog w/ ice. The settings are fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Oct 24, 2010 | Refrigerators
Refrigerator not cooling, at last check 55 degrees, freezer working fine, can not find owners manual help
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
j
Sep 27, 2010 | Amana ABB2227DE Bottom Freezer...
Freezer operates normally, but refrigerator only at 55 degrees at best.
Sounds like a temp control problem, what is the model number of your unit?
Sep 16, 2010 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator Model TFX22KRDA. The evaporator located in the freezer ices over and loses cooling capacity. When turned off and the ice is removed, the freezer and refrigerator both work fine for a few weeks...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 29, 2010 | GE Refrigerators
Subzero does not cool sufficiently, even with cool
yes you have 2 compressor. ona for fridge one for the freezer..
Nov 29, 2009 | Sub-Zero 650/SRH Stainless Steel
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
2,007 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
