Fax with hp 5510 printer all in one
I would like to fax 13 pages to some one without putting the fax # in 13 times. Please help!
Fax from top of machine, not from glass
Posted on Jul 29, 2008
SOURCE:
5510 all in one, my fax has stopped working. I reinstalled the 5510, the wizard set up my fax, it rings, picks up, BUT doesn't do anything else. Try to send and it sounds like it doesn't dial out? It...
First, I would suggest suggest you reset the FAX. If resetting does not solve the problem, you can then read and follow instructions on this link; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669298&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=311255
1. Remove all of the paper loaded in the main input tray.
2. Press the power button to turn off the HP fax product.
3. Disconnect the USB cable from the back of the HP fax product.
4. Disconnect the power cord from the back of the HP fax product and from the electrical
outlet, and then wait one minute.
5. Reconnect the power cord to the electrical outlet.
6. Reconnect the power cord to the back of the HP fax product.
7. Press the power button to turn on the HP fax product.
8. Reconnect the USB cable to the back of the HP fax product.
9. Replace the paper in the main input tray.
10. Use the HP Fax Test Service to try to send and receive a fax.
Good luck.
Mar 24, 2011 | HP Officejet 5510 All-In-One Thermal...
How do i change the phone number on an hp
To change the information contained in the fax header:
Press <Setup>, <3> then <2>
Enter or change info
Press <OK>
I hope this helps. If it does, please vote.
Dec 31, 2009 | HP Officejet 5510 All-In-One Thermal...
HP 5510 Scanner/Copier/Fax Stuck
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
Jan 08, 2009 | HP Officejet 5510 All-In-One Thermal...
Back line on paper
Hello sir; You may try to make a copy direct from glass plateform see there have black line or not, if not ,then you have to clean the piece strip glass on the left hand side of the plateform. that will take care the problem. good luck.
Dec 09, 2008 | HP 5510 4-in-one Printer
Hp5510--will fax, bukt when it prints, the sheet is blank.
First print a standalone test page.
Push Setup >> Print reports >> Self Test report.
If the page prints fine. Reinstall the software. It will work !!
Best Of Luck.
Dec 01, 2008 | HP Officejet 5510 All-In-One Thermal...
After uninstall and installing HP 5510 can not fax or scan
There is a utility called Microsoft Fit it that might be able to help uninstall the older version of the HP Photosmart software from your PC. It is pretty strait forward to run.
Once it is done try installing the software again.
Please let me know how it goes.
Thanks!
Jun 04, 2017 | HP 5510 4-in-one Printer
HP 5510 Faxing problem
hello jeremy
some guides and help from there site here see if this will help you .
riz.
Feb 22, 2008 | HP Officejet 5510 All-In-One Thermal...
Open Questions:
54 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
