Question about Dishwashers
Slow water in whirlpool dishwasher
I have a whirlpool Quietpartner I dishwasher and I am not getting enough water into the dishwasher. When I watch the water filling it is coming into the washer real slow but Ia have great pressure at the feeder hose. Is the solenoid that the feeder hose attaches to the problem and if so how does it come out.
    Sergeant:
  • 351 Answers
Take the hose off the dishwasher and see if the pressure is good,if so the valve is faulty,most of the valves on whirlpool are at the back but you can get to them by taking the base pan off,but check first.hope this helps.
Posted on Mar 12, 2008
Why is my whirlpool dishwasher showing a tap symbol
Even though this video is for a different dishwasher, it gives you the ideas on what to check for. Basically the dishwasher is either getting no water or not enough water.
Nov 29, 2017 | Whirlpool Dishwashers
Code f7 appearing on whirlpool dishwasher adp 6940/5
f7 means a water flow meter problem. Either your dishwasher is not getting proper water pressure, or the flow meter is bad. Check to make sure you have good water pressure to the dishwasher, and then check that your water is coming in at a good flow rate. If both of these are ok, then replace the flow meter. If your house water pressure to the dishwasher is good, but your water flow coming into the dishwasher is slow, then your dishwasher water valve is probably plugged. Some valves you can take apart and clean out, and some you will need to replace. Good Luck, Appliance Specialists
Dec 08, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Quietpartner III the clean light is flashing and the dishwasher won't start.
Hi
Thanks for using FixYa. To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Whirlpool Dishwashers
Dishwasher acts up
sounds like you have a bad chopper. put a cup upright on the top rack. turn the dishwasher on let it wash for about 2 minutes. open the door and see if the cup has water in it. let me know. what brand is this?
Jun 15, 2009 | Dishwashers
Whirlpool quietpartner I Dishwasher wont clean anymore.
you need to take the blades that spin out and clean them off they have grime on them, is there water still in the bottom of the dishwasher when done> if so there is a plastic grate in the bottom rear of the dishwasher you need a 1/4 inch nut driver take the cover off and clean the debris out, there is a small stainless steele cutting blade in there be careful, it is to cut up foods that might not be washed off before putting dishes in the washer, also it is pressure that makes the detergent door open make sure you are getting full pressure comming into the waher, if non of this works the pump should be replace or it;s new dishwasher time
May 30, 2009 | Dishwashers
Dishwasher doesn't clean the top rack whwn we riun it.
sounds like the jets are cloged you can try a small wire to try and unglog the jets that or you water does not have enoph pressuer hope this helps
Feb 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Not getting enough water
you would need to remove the inlet water valve, the screen is just past your installation point
Nov 06, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher quietpartner 2-soap residue
check that the sump screens are clear in the tank,also check that the wash arm holes arent obstructed.
Dec 30, 2007 | Dishwashers
Dishwasher will not fill with enough water
its possible the motor is weak can you hear it bog down when you add the water if so that is probably the problem when the pump gets weak when water is added the pump will not be affected when its good it will slow down change tempo just a little with the motor bad the motor will slow down a lot under a load.
Nov 28, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
99 people viewed this question
Top Dishwashers Experts
