Question about HP Pavilion dv9000z Notebook
Single or dual backlight
I need to order parts for my laptop and for that I need to know if it have a single or a dual backlight display... how can I know it?
  • 148 Answers
The 17 in SXGA + TFT is single
the 17 in WXGA + TFT is dual ...
you can look up your parts at the HP part finder ...
http://partsurfer.hp.com/cgi-bin/spi/main
Posted on Mar 12, 2008
Upper sise of screen flickering problem
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation.
http://www.tech-faq.com/how-to-repair-a-laptop-screen.html http://www.laptop-repair.info/laptop_screen_repair.html b> Hope this helps.
Jan 21, 2013 | Lenovo IdeaPad S300 59359327 Silver Gray...
Sound, but no picture
the problem with your tv (if youve allready replaced the main board) is you have a backlight failure. the board that powers your backlights is called the inverter board. this board only comes with the panel itself and cannot be bought as a single item. if you have any more questions feel free to contact me....
Oct 17, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Where is the backlight resolution located on series 442 e machine laptop
The backlight is built into the LCD screen located on the bottom, the new display will include the backlight.
Jul 06, 2012 | eMachines Computers & Internet
I have an HP HDX 16-1025nr. My LCD got broke and I got a new one.Does anyone know if I can convert the dual lamp lcd to a single lamp? Im pretty proficiant at fixing desktops, but have very little laptop...
Hello Darrel,
Since you promise to repay with advice 10 fold....
Here are some issues you are going to face by changing from a dual lamp backlight to a single lamp.
1) The inverter is designed to drive 2 lamps. You will need to change the inverter as well, or make sure it is compatible with driving a single lamp.
2) Your display was designed for 2 lights originally, this is likely the only way that they were able to get reasonable brightness evenly over the display.
Until you get some more experience working on laptops, just stick to what should be there. As your skills improve, then you can start modifying.
I am guessing that you have discovered the cost difference between single and dual lamp LCDs panels. Bear in mind that those are for the assembly itself. Pull everything out, drop in an assembly. There are a few sources that sell just the LCD itself, and you will have to remove the back light assembly off the original. Again, your skills may not be up to this.
$400 sounds appropriate from HP, but a quick check over at screentekinc.com and sparepartswarehouse.com, though the latter doesn't feature your part#.
Also, here is a decent run through on how to do it:
www.screentekinc.com/lcd-removal-instructions.shtml
Sep 21, 2010 | HP HDX PC Notebook
Unable to get dual diplay with sony vaio laptop with projector I have sony vaio notebook VGNZ56GG/B with NVIDIA 6.14.11.7698 but unable to get dual display when i connect projector to laptop.
Dear User,
Right click on desktop propery and click on graphic display setting, from there you can select single display or dual display, once you have been selected dual display then press apply and ok button.
If this answer helpful , please rate...
Feb 27, 2010 | Computers & Internet
Hi There, I've been experiencing the same setback as Kenneth. My lenovo 3000 flashed off and even if I boot it, the screen is still black.How ca I fix it?./ Ty
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 16, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
No backlight in my lcd but the whole laptop work properly,
Try to connect external monitor to your laptop then hit the short cut keys(see your manual)to use dual monitor. if you got screen on dual monitor. Try to check your laptop screen if something can still be view from screen, if you have then backlighting circuit is to be check. Practical solution is to bring it to a shop if you are not inclined on fixing it yourself.
Jun 16, 2009 | HP Hewlett Packard LCD Display for...
Back light or inverter. my screen is black.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 28, 2009 | Dell Inspiron 8600 Notebook
New laptop lcd display not working
check the panel to make sure the panels are the same model number there are more then one part number for gateway lcds for your model and if your laptop uses the xga screen and your not replacing with the correct panel then you will get the problem you are seeing now.even thought the inverter and back light are the same the panel are very differant.
Feb 18, 2009 | Gateway MT6451 Notebook
HP Pavilion dv9000z Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
