I can see water dripping at a pretty good rate from the water inlet inside the door. I shut the hot water off at the washer box in the wall and the dripping stops.
This is usually caused by a water inlet valve leaking by. The following link explains how to diagnose the problem yourself and repair:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I've included parts sources (if required) and instructions on how to replace each component. These are very simple and inexpensive repairs that you can easily accomplish yourself.
If the model number is correct, the part number for a replacement valve is 8181694. The average cost is about $35.
If you have any questions, please post back and let me know. I hope this helps you.
