Sony Cybershot S650 Digital Camera
Problem for Sony Cybershot S650 Digital Camera
Camera Powers Off Either When Powered On, Or Shortly After
By Rainbowzz on Mar 12, 2008
Hello there!
I've got my sister's camera here, and have been using it the last couple of days to take a few pics of my newborn.
It has developed an odd problem.
Yesterday I got a notice on it saying the battery was low, and the screen was very blurry. I bought some new batteries, and popped in a fresh set. This worked for maybe fifteen min, and I had only taken maybe four pictures. Then, it suddenly shut off when i pressed the shutter button. I tried to power it back on, and would get the Cybershot screen, and then it would blank off again. This continued for several minutes, and then it finally came on for me, and gave me warning that the batteries were low. These were brand new batteries. I tried ANOTHER new set, and went through the same thing in the space of a few minutes.
It seems to be eating batteries in a VERY short period of time(like five to fifteen minutes) When it is not being used very much at all.
What could be causing this? Is it a repair issue?
Comments:
Mar 25, 2008
- hi there.
I actually was able to figure it out - I was using crappy batteries. I have since switched to lithium batteries and it is working again perfectly. Thanks though :)
Same Problem
May 15, 2009
-   ill be taking pictures and once i taker a few it just shuts off.
and once i try to turn it back on, it just shows the cyber-shot screen then turns off again. i've replaced the batteries a number of times and it still won't work.
-   acolpitts
Solution #1
posted on Mar 25, 2008
Somewhat Helpful)
mcomijohns
Rank: Guru  Sony Expert
Rating: 86%, 405 votes
In the cameras menu try finding the reset feature. once it is reset test it out also check to see if the cameras flsh is working if it is and then the batteries are dead then it has a bad flash compasitor because it has to charge up and release the charge to the flash but if the compasitor nevr fully charges it keeps tring to charge it and the batteries drain fast. It can be repaired. Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Sony Cybershot S650 Digital
Questions and Unsolved Problems for Sony Cybershot S650 Digital
Do you recommend Sony Cybershot S650 Digital Camera?
Answer
Answer
when i switch on my dsc-s700 model it blinks format error on the screen
Answer
how to reduce size of picture or crop once you have downloaded to computer
Answer
when i turn the camera on all i get is a blank screen
Answer
when you turn on the camera it dosent focus and tells me to turn off power and turn on again...keeps... (More)
Answer
it wont open and all its says it something with an error
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Cybershot S650 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
