Question about Philips 27PT5441 27" TV
TV won't turn on.
Philips 27PT5441 just decided not to turn on any more. I tried plugging into a couple different outlets- nothing, no poof sound that it used to make when turning on. It won't turn on by remote or from switch on front of the tv. Totally dead. Any thoughts on how to get it to power on again? Thanks
  • 5 more comments
  • PBRtime Mar 14, 2008
    The fuse was blown, I replaced it the TV works again. Thanks
  • Lurd Apr 15, 2008
    How do you replace a blown fuse? How much does it cost to have something like that fixed?
  • Lurd Apr 15, 2008
    How do you change a blown fuse? How much does it cost to have the fuse repaired?
  • kclyles Apr 28, 2008
    After a thunder storm, my TV quit working. No power was going to the set. I tried a different plug to no avail.
  • Anonymous Jun 06, 2008
    for the past couple of months it would take ten mins to turn on the tv because each time i'd turn it on it would immediately shut off. now, the tv won't turn on at all. do you think it is a blown fuse in this case?
  • EMPIRE_RECYC Jan 01, 2009
    WHEN I TRUN ON MY FLAST SCREN TV IT WONT TURN ON ANY MORE IT USED TO HAVE A LITTLE GREEN LIGHT AT THE BOTTM LEFT HAND CONNER AND THEN TRUN ON NOW THE LIGHT WENT FROM GREEN TO RED AND WONT TRUN ON?
  • Anonymous Mar 19, 2009
    how much a blown fuse cost
  • Philips Master
  • 1,257 Answers
If the fuse is good and you will see this when the board is out....You definitly have a bad cap if horizontal deflection. Always suspect a 200 volt capacitor at 1 MF. The caps that go down first are 160volt to 200 volts and less than 10 MF. Always suspect these. And sometimes a 25 volt 47MF cap will be bad in these TVs....been sometime since I repaired one of these aging sets. And another thing to ad is a cap behind the flyback, location 2465 at 100volts 10MF is going bad, replace with care as the PC trace is delicate....becareful. And always look extra close for bad grounds under those transistors!
Posted on Mar 09, 2010
  • 1 more comment
  • matt martin
    matt martin Mar 09, 2010
    Let me ad this importnt fact..You will need to install the horizontal kit...#4835 310 57673
  • matt martin
    This will correct the horizontal timing and everything will come on at the same time!
  • matt martin
    Factory approved!
  • 148 Answers
Sometimes holding down the on button and plugging it in works. If not looks like the fuse for the power button is out.
Posted on Mar 12, 2008
SOURCE:
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
My tv only works when i switch the room light on
It sounds to me like you have the tv set plugged into a switched outlet. To check this, I suggest you plug a different device (such as a lamp) into the outlet and see if it does the same thing.
If possible, try plugging in the tv to a different outlet.
Der Strom
Apr 23, 2010 | Philips Televison & Video
Watching and Suddenly turned black, but sound still worked.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It seems there is a loose connection between the board producing the picture and the screen; this is why this would happen. If turning the TV on and off makes no difference, try contact Phillips to see if they can talk you through a factory reset. If this does not work, the set may require service.
Jul 16, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Blows Fuses
Hi
They have so many reasons why blown fuses in TV... all you have to do is to check the shorted semiconductor like regulator and drivers..
Thanks!
Feb 24, 2009 | Philips 27PT5441 27" TV
Westinghouse LCD TV Not Working
Hello, I have a Westinghouse LCD; model # LTV-20v2SL and it stopped working. I had turned it on, then it just went off...I tried using different outlets, unplugging for a moment or 2 and then re-plugging in; nothing. It was purchased a couple of years ago; fairly new. Any suggestions? Thank
Jul 20, 2008 | Westinghouse LTV-20V2SL 20.1 in. ED-Ready...
Phillips model 25PT4475/48
fi you take the back off take a look at the board and if its got a crake sorry but its caput/means can't help ya
Apr 17, 2008 | Philips 27PT5441 27" TV
Philips 27pt5441/37
Hi there!
Dead short either in the power supply or rectifier, or PTC faulty.
PTC is cream in colour close to the mains on/off switch. Regards, JUS004
Mar 22, 2008 | Philips 27PT5441 27" TV
TV was Fine last night, this morning there is picture, but no sound
Since the you were vacuuming behind the set before this happened, I'm going to assume that you unplugged an input. Check the wiring, not just on the back of the set, but, on the back of the peripherals (DVD, Satelite, cable box, etc.) If wires are connected, then, take a component, such as a VCR or cable box and hook it up to the RF connector (AKA the cable connector) and run it on channel 3 or 4. If you have sound, then, you have a configuration problem and need to rewire your set. Hope this helps.
Mar 17, 2007 | Philips 27PT5441 27" TV
Sound problems European TV in UK
Europe uses a different sound carrier than the UK Europe = 5.5mhz UK = 6.0mhz some sets can be switched in the customer menu others will need to be modified (although this in some cases may not be cost effective)
Mar 05, 2007 | Philips 27PT5441 27" TV
Philips 27PT5441 27" TV Logo
223 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
