Question about Bosch 24 in. SHU43 Built-in Dishwasher
Shu4302uc I have a Bosch SHU4302UC Dishwasher and the Regular Wash and the Clean indicator lights are always on. It just keeps running and running and does not seem to go through an entire cycle. I can choose any other cycle and it does the same thing---it continuously runs and the clean light is always on.
  • 2 more comments
  • roger l teutschmann Mar 14, 2008
    No the water does not heat up.
    I have a Bosch SHU4302UC Dishwasher and the Regular Wash and the Clean indicator lights are always on. It just keeps running and running and does not seem to go through an entire cycle. I can choose any other cycle and it does the same thing---it continuously runs and the clean light is always on. The water does not heat up.
  • roger l teutschmann Mar 16, 2008
    Sorry Dave. I was having trouble navigating the site. You mentioned you know what the problem is and how to fix it. What is the solution? Thank you.
  • David Duffell
    David Duffell May 11, 2010
    Hi There,
    Does the water heat up?
  • 30 Answers
Hoe can you rate a question about a dishwasher that dose not work inappropriate????
Please think before rating, or no one will give you advice, and you'll just have to pay the repair-man whatever he tells you it costs.
I actually know what is wrong with your machine!
Dave
Posted on Mar 15, 2008
No, the water does not heat up. Thanks.
Posted on Mar 13, 2008
Bosch SHU4302UC/UO6 runs three hours.
Maybe wash temperature. The machine may be trying to heat the wash water to a preset temp and it is taking an extended time to get there. Maybe a faulty temperature probe or a bad element?
I know you will ask how this is possible when you have a final temp of 120 but that sound like a drying cycle temperature to me; not a wash temp.
I would leave the thermometer in through the cycle and you will probably find it will slowly get hotter in wash cycle and finally switch after a certain temp has been obtained.
Oct 05, 2017 | Bosch Dishwashers
I have a Bosch dishwasher Model number SHU4302UC. The dishwasher takes about four hours to wash dishes. During the rinse cyle it can be running for over an hour and I will open it to look in side and find...
possibilities are that of an inefficient heating element ie..scaled up if hard water area especially. whilst the cycle is being completed then the components are working... so other than the element check the drainage for blockages (slow draining adds time) & also water pressure as low pressure adds time to the filling..
Dec 21, 2009 | Bosch Dishwashers
Bosch built in dishwasher shu4302uc The dishwasher appears to run through the cycle but the cycle takes over three hours. When the cycle finally finishes the dishes are not completely dry. Is there a way...
There are no adjustments for cycle timing. What does affect timing is temperature of the water coming into the DW. The hotter your supply water, the shorter the time to cycle, BUT if your water is too hot, the cycle time may become too short to light the NSF 'Sanitize' indicator. But since the cycle is taking so long, this is an indication that the DW's water heater is not heating the water hot enough to advance the countdown timer in a timely manner. The control logic is waiting for the temp to come up to an appropriate level to ensure adequate washing, rinsing or drying times. Likely your display is showing '1' for a long time as a symptom of this problem, as well.  - This link http://www.applianceaid.com/boschDW.html has procedures to run self-tests on various Bosch models. I suspect that you can confirm a 'heater fault' on your unit by running the self-test.  - This problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. If you have a Torx driver, soldering iron & bit of solder, you can effect a repair yourself in about an hour. Otherwise, a replacement control board is required.
If you'd like to attempt replacing the control board yourself, refer to this link for part & DIY information. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
- Else, place a service call to the tech of your choice.
Feb 22, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU4302UC/06 Sound Like It is Work But NO WATER
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 15, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Running a LONG LONG Time and Watering Remaining
You could try running the machine with the drain hose leading to a large bucket. If it works OK in this situation then the blockage will be most likely where the drain hose joins the house drainage system - often at a junction under the kitchen sink. With the drain hose disconnected you should be able to see the blockage and clear it with a suitable pointy tool.
Let me know if this sorts it. Thanks, D.
Jul 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwahser rinse cycle running for hours
Do you have high temp rinse or sanitize selected? This will pause the timer during the final rinse cycle to heat the water. The sensor might be bad. Try the quick cycle, I don't think this heats the water.
Jun 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher shu4302uc
Common problem with these. Control panel (behind all the buttons on the door) has a thyristor in the middle of the PCB for switching the heater element ON/OFF.
After many screws and a bit of fiddling about, get access to back of PCB (print side) to find dry joints. Clean and re-make joints and all should be well.
Caution, this is a high voltage area. Disconnect from mains.
Please see photos.
Cheers…..Dave
Mar 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
430 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
