Question about Whirlpool LGR5636L Gas Dryer
Whirlpool gas Dryer LGR5636JQ1
Dryer blows but no heat. Took off front of dryer and the igniter does not get hot. Could there be any other problems other than the igniter being bad?
  • Historygeek1 Oct 17, 2008
    This is pretty good stuff. The switch wires are blue though, and are found on the back on the black filter ducting inside the rear cover, near the bottom of the back panel.
    I think mine is the igniter, as there IS current when on, but it is cold and blows cool air forcefully.
    I'll know more after replacing the igniter
    President:
  • Whirlpool Master
  • 2,651 Answers
Theres a thermal fuse located on back panel usually white maybe 2 inches tall 1/2 wide 2 blue wires leading to it. ck for continuity, if none replace that(most common problem)... if good you can go back to the ignitor and unplug the white connector it plugs into. place your meter leads into the connector and turn on dryer, you should get 110v. if you do you have a bad ignitor, if not a thermo's gone bad (check the thermal fuse first though.
Posted on Mar 12, 2008
SOURCE:
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
I looked through the peep hole in front of my gas dryer and I don't see anything lit.Dryer spins great, but doesn't heat up. What is the problem?
Igniter - The dryer's igniter is what ignites the gas that has entereddryer-ignitor.jpg through the gas valve. It will glow red, then when it reaches a certain temperature, it will trigger a thermostat that opens up the gas valve and that's when the dryer starts to heat the air. If the igniter has failed, the motor will still run but not produce any heat.
Jan 31, 2012 | Whirlpool Dryers
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 | Dryers
Dryer does'nt blow hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 31, 2010 | Whirlpool LGR5644 Gas Dryer
I have a whirlpool gas dryer. Model# WGD55505Q0, Runs and blows air. no heat. I Shook the dryer and it worked 4 a few minutes. Now nothing
The problem sounds like the gas valve solenoid coils has gone out. Remove the front panel to access and have a view of the burner assembly then start the dryer to check whether the igniter glows red hot or not. The solenoid coils are indeed not working and need to be replaced if the igniter glows red hot but no gas is ignited.
Disconnect power to the dryer then pull the lint filter out and remove the screws near the opening.
Insert a putty knife or similar tool between the top panel and the front panel to release the clips securing the former to the latter on both sides as shown then rotate top panel up to the rear of the dryer.
Remove the front panel screws then lift the panel up and swing it to the side. Do not disconnect door switch since you are going to start the dryer.
You now have access and view of the burner assembly. Plug the dryer in then start it. Unplug the dryer and disconnect the flame/radiant sensor if the igniter glows red hot then plug the dryer back in and restart it. Replace the flame/radiant sensor if the dryer heats up with the sensor disconnected.
Replace the solenoid coils if the dryer still does not heat up if the igniter glows red hot and the flame/radiant sensor disconnected. Disconnect the wires from the coils and remove the screws from the bracket then pull the coils out. Slide the new coils in then secure it with the bracket and reconnect the wire harnesses.
In case the igniter does not glow, remove the back panel and bypass the thermal cut-off and the high-limit thermostat. Disconnect the wires shown then jump a wire between them and the two are bypassed.
Start the dryer then check again whether the igniter now glows or not. The igniter is broken, probably due to the shaking, and needs to be replaced if it fails glow now that the thermal cut-off and the high-limit thermostat are bypassed. The igniter is very fragile and easily breaks. Extra care must be done when handling it to about breakage.
Either the thermal cut-off or the high-limit thermostat has failed if the igniter glows with the two bypassed and the dryer heats up. Most likely it is the thermal cut-off but in either case, both of them must be replaced. Simply unscrew them from the box then install and secure the new ones. But if the dryer still does not heat up even with the flame/radiant sensor disconnected, the solenoid coils also need to be replaced.
Feel free to update us about the troubleshooting and repair. This is a pro bono service and rating the advice/solution should you find it helpful as a gratitude will do and much appreciated. Do not hesitate to ask further questions should you need clarification if something is unclear or not applicable before giving an adverse rating.
Disclaimer: This advice is intended solely for the asker droot559 and tailored specifically for his/her problem. It may not be applicable to other dryers and may fail to address heating problem. Post your own problem and include the make and exact model number of your dryer for the specific advice on how to address your problem.
Aug 17, 2010 | Whirlpool Dryers
Dryer turns and air blows, but no heat. GGQ8811KQ0
Make sure that your dryer air vent is not being blocked by lent, and if it is not it is your element or thermocouple?
Nov 07, 2009 | Kitchen Ranges
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
I have a whirlpool gas dryer.  heats up for a minute than get gool. will not stay hot?
check your exhaust vent to make sure that it is not blocked up with lint. If not then check to see if the flame comes on after the igniter check the peep hole in the front of the dryer.
Dec 28, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LGR5636L Gas Dryer Logo
336 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
