Question about Vacuums
Hw do you take bottom to relace belt?
We have an old upright that works but needs the belt changed. It has no screws to take the bottom off. We have a place that sells the belts. Please email me @ jmduboiswinters@aim.com with answer. Thanks in advance.
Joanne
  • joanne2850 Mar 13, 2008
    advance.
    If no screws on the bottom, then they must be on the top cover. You
    didn't state brand or model number, so it is hard to tell what you have.
    It's a Hoover Concept One upright and there are no screws anywhere to dissemble the bottom.
It took a lot of searching but I found this and it helped me with the Hoover Concept One.
http://dl.owneriq.net/6/6d5bd50e-d120-4a0e-aea0-53445628fa8e.pdf
Posted on Apr 28, 2010
    President:
  • 1,673 Answers
If no screws on the bottom, then they must be on the top cover. You didn't state brand or model number, so it is hard to tell what you have.
Posted on Mar 13, 2008
  • Lauren Junge
    Lauren Junge Mar 13, 2008
    The model number is on a tag probably on the bottom. Some of the older Hoovers didn't use screws. The bottom plate has catches, usually 2 of them to undo to remove it. The top cover on some had tabs, there should be slots from the bottom edge that you can fit a flat blade screwdriver into, pry out and up to release them. If I had the model number, I might be able to look at a picture of it and can tell you better.
Replace belt genesis upright
Turn vacuum upside down on flat surface, remove the 6-7 screws from the bottom of the power nozzle, lay it on it's side and pry on the two accessible internal tabs to pop top cap of the nozzle off to access the pn motor assembly. Lay flat on it's back again and remove the screws that hold the roller brush in, remove the roller brush, remove old belt, install new belt on brush roll and pn motor geared spindle, push brush roll back in place, replace screws and pn top and VOILA!..you're back in bidness! Hop that helps!
Jun 25, 2014 | Electrolux Vacuums
I cannot find my owner sheet and need to change the belt in my upright oreck
THERE IS A SINGLE SCREW ON THE SIDE OF THE VAC KNOWN AS THE 'BELT DOOR'.
LAY VAC ON IT'S RIGHT SIDE, SO THE BELT DOOR IS STICKING STRAIGHT UP IN THE AIR. REMOVE DOOR AND BELT DOOR. CUT OLD BELT IF IT IS NOT BROKEN. TUCK NEW BELT UNDER BRUHROLL PULLEY FIRST THEN STRECH OVER MOTOR SHAFT.
DO NOT REPLACE BELT BY REMOVING BASEPLATE. 1) THE MOTOR IS NOT STABLE ENOUGH FOR THE TIGHT BELTS WITHOUT THE SUPPORT OF THE MOTOR 2) REPLACING BASEPLATE IMPOPERLY MAKES VACUUMING DIFFICULT. ">
Feb 18, 2011 | Oreck XL21 Bagged Upright Vacuum
Trying to change the belt
things you will need Vacuum belt
  • Screwdriver
  1. Locate and purchase the correct belt for your Eureka vacuum cleaner from the local grocery or department store. Vacuum belts come in different sizes according to your model of vacuum. Check your owner's manual or the vacuum itself for your model number.
  2. Turn your vacuum cleaner over so that the bottom of the unit is facing you. Remove the cover plate from the bottom by undoing the screws that are holding it in place with a screwdriver.
  3. Locate the belt pulley rod near the back of the vacuum base coming out of the motor. With the vacuum cleaner base turned upside down and facing you, the motor and pulley rod should be up near the top of the base.
  4. Slide the vacuum brush roller out of the slots at the bottom of the vacuum base and remove the old belt from the brush roller and pulley rod. With the brush roller off of the unit, clean the brush by removing any strings or cords wrapped around the tube.
  5. Install the new belt by looping it over the belt pulley rod next to the motor and then looping around the end of the brush roller in the belt slot. Hold the brush roller and pull back on it to tighten the belt while you slide the roller back into the slots on the vacuum base.
  6. Replace the base cover plate by snapping it back into place and securing it with screws. Turn vacuum back upright and turn it on to test the belt and verify the unit is working
Feb 16, 2011 | Eureka Surfacemax 200 Bagless Upright...
8955 Upright Vacuum: How to change belt?...
Be sure to unplug your vacuum from the electrical outlet before proceeding!
-Turn your vacuum upside down so that the handle is resting on the floor and nozzle portion is resting on a work bench.
-Remove the 2 phillips screws from the metal bottom plate and set the bottom plate aside.
-Look at the right side of the brush roll. You will see a bent metal rod that attaches to the brush roll end cap. This is the clutch rod that allows your brush roll to spin or not depending on the position of the carpet/floor switch on the top of the nozzle. Pull this rod out of the brush roll clutch only. Leave the switch end of the rod where it is and just let the rod rest there.
-Pull the brush roll and old belt out and dispose of the old belt.
To install a new belt; put the new belt on the motor shaft first, next put the other end of the belt over the end of the brush roll and stretch belt and brush roll back in to place. Notice that on the brush roll end cap opposite of where the clutch rod goes, there is a metal piece with a slot cut into it. Be sure that this slot mates with the plastic stop in the nozzle so that the end cap cannot move.
Snap the clutch rod back in place and rotate the brush roll by hand to make sure the belt is not pinched.
Replace the bottom plate.
May 18, 2010 | Riccar 8955 Upright Vacuum
Changing the belt
Always make sure your machine is unplugged from the outlet before replacing the belt.
Newer Oreck uprights have an access plate on the right hand side of the base (as you're looking at it from the front). Remove the one screw from the access plate and slide it forward. Snake the new belt around the brush roll pulley and then strrrrrrretch it back to the motor shaft. Replace the access plate.
If your model does not have an access plate; turn the machine upside down, Remove all screws. Lift the bottom plate off. Observe the position of the brush roll ends, One side of each end cap will have several notches cut into it,this is the 'new' side, the other side is smooth, this is the 'old' side. You can reposition the brush roll the the 'old' side if your bristles appear worn down.
With the brush roll still removed; place one end of the belt over the motor shaft first, place the other side of the belt around the brush roll pulley and stretch the brush roll forward until it is back in place.
Spin the brush roll by hand before replacing the cover to ensure the belt is not pinched.
Replace to cover.
May 16, 2010 | Oreck XL Ultra Bagged Upright Vacuum
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
How do I change the belt in an upright vacuum?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=755349
How do I change the
Posted by budnvic on Jul 08, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Well, I can try to tell you a how to for a generic vacuum, but we really need more information as per the brand name and model # in order to tell you the best way to change the belt on your current vacuum. Most vacuums have a removable bottom plate o which will release by screws, clamps or levers and the bottom plate should come off or the top cover will come off. Then the belt should be exposed. Then cut off the belt, lift up on the brushroll side where the pulley is and place the belt on the pulley, then reinstall the brushroll – now use a belt puller or screwdriver and pull / stretch the belt onto the motor pulley – then track the belt by rolling the belt in a straight line – if the install worked then reinstall the top cover and or the bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jul 08, 2008 | Vacuums
Belt is broken
Most upright vacuums will have 2 screws on the bottom of the vacuum. Remove both screws and snap off bottom cover to get inside of the head. Remove old / broken belt and slide agitator off from the head unit. Stretch new belt with both hands then place around the agitator and pulley coming out of the motor. Place the agitator back into place (there will be some resistance from the new belt, but that is common). Put back on the bottom cover and place back the screws. You should be all set then. Hopefully this helps.
Mar 14, 2008 | Fantom Vacums CW600 Upright Vacuum
Vacuums Logo
109 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
