Finalize disc How do I finalize a disc after I recorded a movie.... I cannot play in other devices if not done... P[lease help
  • TOP10NLA May 22, 2008
    I have a LITEON LVW-1105HC DVD recorder that i've lost the manual to. I'm trying to set it back up after a recent move and cannot remember the connection order for vcr, tv, dvd player, cable box and receiver. I need the setup information.
On the bottom of the Proton PD-DVR100 select Disc Edit. Us the up down arrows on the remote to select finalize disc. Select Yes, press Enter. The disc will finalize to be used in other DVD players.
Posted on Mar 18, 2008
  • 807 Answers
Is that in a PC or a standalone DVD Recorder.
If it's in a PC then the burning software you use sholud have it in the help file.
If it's a standalone DVD Recorder it will tell you in the user manual. If you don't have it and you can post the make and model number of the recorder someone here may be able to tell you where to get it from.
Posted on Mar 12, 2008
Can DVD'S be fixed to play on any dvd player?
,THATS GOOD NEWS. cheers,,. u don't mention what recorder u r using when u put the tdk-R IN,,, DOES IT TELL U TO format the disc ???????? if it does and u don't format it will not record on disc Hi again if u wa?t to use RW rewritable disc's then u don't have to finalize them to play on other DVD players u can buy rw disc's on ON. E/EBAY Cheers.,..,..,...., try another brand of disc like TDK .THEY R GOOD ..when u have recorded a movie go into youre menu and find FINALIZE ..when u have finalized the disc it will play on most dvd players good luck
Oct 19, 2015 | Televison & Video
I am able to copy my vhs to dvd on this device and it will play back on this device but the dvd's will not play on any other player. Can you help with this please?
Not completely sure about the "device" you used to make the recordings, but most likely the reason for them not playing on another player is that whenever you record DVDs, in order for them to be readable by regular players, the DVD must be "finalized". Once that is done, and the device you used to record the DVD should be able to do that, then you should be able to play them on a regular DVD player. Know this, however, that finalizing the disc means that no more data can be recorded to it.
Sep 01, 2015 | Televison & Video
Can't view recorded DVD
if the movie you recorded ? was copy protected. then your dvd prob did not record
Nov 22, 2012 | Magnavox ZV427MG9 DVD Recorder/ VCR
Finalize a Disc on Mangavox MWR10D6
No. Generally finalising just writes the unused spaces as unused so the player knows and adds a stop code. The shorter the DVD the longer the finalise. An hour and a half on two hours is plenty of space.
Apr 13, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Won't play on any other dvd
You have to use your friend's DVD recorder to finalize the disc. Once the DVD is finalized, it will play in other DVD players.
On your friend's DVD recorder, pop the disc in, and use his remote to go to Setup --> Disc Edit --> Finalize --> OK
Voila!
-Tha Mp3 Doctor
Feb 14, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Burning home movies from recorder to disc
make sure its finalizing the disc you may have to go into menu or options to check, but if plays in the but not in standalone thats sounds like the problem.
Feb 13, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
DVD unable to play tv recorded items
If you can see recording on the flip side..it is either a disc patch fix (software) obtained thru Go Video..or find another go video recorder to finalize it..you might try unplugging the unit for a minute or two..and try it again...
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Playing recorded dvds on another player
Re-finalize one more time. On some Philips/Mag players, finalize fails the first time.
If it still won't work, then use a computer program like Dr. Divx to finalize the discs.
Aug 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd recorded movies will not play on my other dvd players
Before removing the DVD from the recorder, it must go through a process called finalization. Once you finalize the discs, then it will be able to be seen on most DVD players. Check your recorder's documentation on how to finalize your discs.
Jun 23, 2008 | HP Pavilion zd8000 Notebook
Dvd-ram 4.7gb
DVD RAM discs don't need finalised, hence its not an available option.
They will play directly on other players -*** BUT*** ONLY DVD
RAM players.
Don't expect your RAM disc to play on a normal
DVD+/-RW DVD +/-R device. Its not going to happen unless the
device supports DVD RAM also. If it does, it will play your RAM
disc once you've finished recording in your own DVD RAM
recording unit. Pop it out of your unit, straight into the other, and
the jobs done.
Nov 02, 2007 | Panasonic DMR-ES10 DVD Recorder
Open Questions:
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Electro Med Services...
