Question about Kenmore 24032\24036 Top Load Washer
Coupler gear repair
I'm having the same problem as another person you responded to:
You posted:
your drive coupling is broken you need to get Whirlpool part number 285753 you can change this yourself.. post you email plz i will send you the procudure
Can you send me the procedure to repair the drive coupler? I have a Kenmore 80-series super capacity model 110.29852991. The unit will fill up, pump out, won't spin & makes the grinding noise. Is this hard to replace? How do I get the back off of the washer?
My e-mail: morgan61003@frontiernet.net
Thanks, Tom M.
  • 2 more comments
  • CaptAm Mar 22, 2008
    Installed a new couper and problem is solved! Thanks a bunch. Saved me over $100.
  • RJC 1983 May 01, 2008
    Hi I have the same washer but it will not dump water nor spin.I was told i probably needed to change the motor coupling but i'm having problems getting to it. DO you recommend changing the coupling or does this sound like a different problem? If this does sound like a coupling issue how do i get to it?
    My wife has a pile of laundry so i would appreciate it if you could either e-mail me at randall_crowder@yahoo.com or reply to this posting whenever you get the chance Thanks in advance.
  • Anonymous May 05, 2008
    I have the same problem. I know that it is the coupler, but do not know how to dislodge the old coupler to replace this one.
  • Anonymous May 08, 2008
    I'm having the same problem. I have no idea on how to get the back off to look and fix this prob. if you could e-mail me the procedure I would really appreciate it thanks Erick Tollen (tollen17@yahoo.com)
  • 770 Answers
Check your email
Posted on Mar 15, 2008
Maytag fav6800aww how to disasemmble
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
GRINDING NOISES:
The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it.
Sep 28, 2014 | Maytag Neptune Washing Machines
Lg front load washer mod# wm2301h, (2 years old) makes grinding sound during wash and spin cycle
check ur motor coupler
GRINDING NOISES:
Oct 13, 2012 | LG WM2301H Washer
Washer will not spin the water out
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Jan 04, 2011 | Whirlpool Washing Machines
Kenmore 70 series. it wont spin, motor works, itook it apart to look for broken parts nothing looks broken maybe the small tefflon parts are worn, can you tell me what to look for?
Whirlpool washers (such as your Kenmore) use a motor coupling in place of a drive belt. It is located between the drive motor and gearcase (transmission) and couples the energy of the drive motor to drive the gearcase. This configuration is known as a "direct-drive" system. From the symptoms you describe, this sounds like a simple broken motor coupling issue. As the washer ages, the coupler can break after years of use. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is inlcuded with the instructions I provided. Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. For a pictoral view of the coupler (3 small pieces) refer to the "Brake, Clutch, Gearcase, Motor and Pump" parts section and look for item 13.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid). I hope you find this information helpful.
Dec 22, 2010 | Kitchen Ranges
I can hear the motor but the agitator doesn' t move
This is likekly the motor coupler. This is easy to replace and inexpensive. Here is a link that will walk you thru inspecting and replacing the motor coupler. http://appliancehelponline.com/topdirectdrivevideo.html
Sep 07, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kenmore Elite 3 Speed washer, Model number 110-22982-100. It wont spin, but the pump is working. Do you know if this is belt driven or if it has a coupler? I need repair diagrams if you have...
Your washer is a direct-drive model which means it uses a motor coupling instead of a drive belt. The symptoms your washer exhibits is typical of a motor coupling gone bad.
If the washer will fill and drain, but won't agitate or spin, the most common cause is a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. This configuration is known as a "direct-drive" system. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased for about $10 - $15. The following websites are great sources for replacement parts:
repairclinic.com
If you have any questions about this repair, or if you require additional assistance, pease post back and let me know. I hope this helps you.
Jan 29, 2010 | Kenmore 24032\24036 Top Load Washer
My washer wont agitate or spin and is making a strange sound when it should..Please help
You need to change the motor coupling.
The part number is 285753A.
Remove the top panel and take the cabinet loose buy remove the two gold clips that holds it down to the back panel.
The coupling is between the motor and the gear case.
Sep 03, 2009 | Roper RAX4233PQ Top Load Washer
LOAD NOICE WHEN SPIN
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking.
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you find the motor coupling still intact, the gear case (transmission) may have failed. The repair cost (if you do this yourself) is about $150 or less. If it comes to a failed gear case, and you wish to pursue the repair, the following link explains how:
It seems like a lot, but its actually an easy repair. I would still begin by inspecting the motor coupling, though. This is the more common fail item.
If you have any questions, please let me know. If you need assistance in diagnosing your symptoms, post back and elaborate a bit more. I hope this helps you.
Thank you for contacting Fixya.com
Aug 05, 2009 | Washing Machines
Replace Coupler
This is something that can be done yourself and is very easy. First on the console you will find 2 screws depending on the model the screws can be in the front behind the plastic end caps ( you will have to pull it from the top and it will come down ) or in the back of the console on the left and right sides. after you remove the screws the console can be pulled to the front of the unit and flipped up, you will see a brass clamp on the left and right, take a flat blade screwdriver and pop them out, now disconnect the lid sw and open the lid and pull the cabinet toward you lift up and out this will expose the whole machine. now get on the floor in the bottom center of the unit you will find the pump held on by two clips pop off the clips and pull the pump off the motor ( when reinstalling the pump make sure the motor shaft and the female part on the pump are lined up ) now disconnect the motor wires and in some cases remove the 2 5/16th screws holding the 2nd pair of clips in place if your unit does not have the screws pop off the 2nd pair of clips , now with the motor out you will see the coupling one half on the motor and the other on the shaft for the trans,you can pop the parts off with a flat blade screw driver. now you are ready to install the new part. place the end of the new coupling on the motor use a 3/8 socket and tap the part on till its flush with the shaft, do the same with the trans coupling also now put the unit back together and your set to go. Hope this helps
Jan 06, 2009 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
143 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
