Question about Disney DTD1363-CAR 13" TV/DVD
Disney DTD1363-car, Need part # of transistor
Need the part # and where to order a horizontal output transistor for a disney dtd1363-car. Number stamped on transistor is p5nk 50zfp gk180 chn 607
    New Friend:
After turning tv on it shuts of quikly why it
Posted on Jun 27, 2011
The transistor is a 2SC5885 & can be purchased from Audio Labs.
Posted on Jul 23, 2008
The tv keep shuting off an the dvd door won't open. I have model # DTD1363-CAR
Is there any recall on the tv
Posted on May 21, 2008
SOURCE:
The screen is red
Hello
The horizontal output transistor for Red color output is shorted. Replace it with same type and number.
Feb 28, 2012 | Disney DTD1363-CAR 13" TV/DVD
Onida 21''ctv picture coming in stamp type {cutting from four sides}
Hello
Replace its Horizontal output Transistor. If the base-emitter junction has a leak inside it, this type of fault will occur. Before replacing it, check the main DC voltage to LOT [Line Output Transformer]. It should come around 102VDC. If there is not this much voltage, check the electrolytic filter capacitor connected across thie supply line to main negative for open or value developed. Replace the same is good. Till there is low voltage found, check the retifier diode that rectifies this 102 volt DC. If all the above are OK and still you get a stamp like raster, check the heat of the Horizontal Output Transistor described above. if it overheats, LOT is defective and should be replaced with same type and number. OK.
Jun 12, 2011 | JVC Televison & Video
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
32gt660 (ctc187cn3)
The flyback is availabel as part number 223952-rep from tritronicsinc.com at a cost of $29.00 US.
Please replace the horizontal output transistor wih the correct one as well: Part number 223942 available from above at a cost of $15.49
Dan
May 20, 2008 | Sony KV-32FS13 TV
Disney TV prob you helped me with.
I could not find anything schematic for your TV.
I would suggest to check the horizontal transistor, if the transistor is OK; check the voltage at the collector. NOTE: be very careful when measuring this voltage, you should get about 130 VDC.
If that voltage is present, you might have a defective flyback transformer.
Mar 25, 2008 | Disney DTD1363-CAR 13" TV/DVD
THANKS
I will say that this part is shorted if it measures continuity on all the leads regardless on how you tested.
Was this mosfet nearby the power supply circuitry?
You can also check the horizontal output transistor that is mounted on a heatsink near the flyback transformer.
Mar 12, 2008 | Disney DTD1363-CAR 13" TV/DVD
Fuse blows, Disney DTD1363
It look like this is the PN p5nk50zfp.
This site has your part. Data sheet
This part, it might be your voltage regulator not the horizontal output transistor.
Good Luck.
Need a part # and where to order a horizontal output transistor. stamped on transistor p5nk 50zFP GK180 CHN 607
hori out puts numbers are like D1581, C1551,or NTE2973 NTE2324 and so on None of the numbers you have cross over to anything.
Mar 12, 2008 | Televison & Video
Disney DTD1363-CAR 13" TV/DVD Logo
319 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Dalynn Turner
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
