A vertical line goes arcoss the screen when i turn it on. done some research and concluded it would be the vertical capacitor has a loose wire. Ive gone to a couple repair shops and their askin alittle too much to look at it. I was wondering if i could fix it myself. Im looking for a map of the insides so i can locate the problem. Is there any way you can help?
  • 5,138 Answers
If you know how to solder try resoldering vertical out put ic ,look for 35uf 100v capacitor.
Posted on Mar 12, 2008
SOURCE:
China tv kit
Horizontal sweep absent, is the fault. Vertical sweep is OK. Check for any loose solder terminals or loose connection at the connection goes to deflection yoke. Check all the capacitors related to horizontal scan output. google.com/+GopakumarGopalan
Nov 18, 2013 | Televison & Video
Dell Ultrasharp 2407 monitor - Vertical lines
most likely capacitor problem as these caps only have a 25000-40000 hour life span. when you do replaace the monitor , turn it off when not at the computer. even though it goes into sleep mode there is still a current running through the unit cuz if you move the mouse or hit button on keyboard display wakes up. I know this because I have done boad level repair on panels
Feb 04, 2013 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Suddenly my ac went stopped blowing cold last night. I have tryed everything. I cleaned the coils. I changed the filter. I changed the capacitor. I had the freon levels checked. I checked the contactor (...
So your lines get cold and hot when the compressor goes off? If your bigger copper line is cold and the smaller one is hot then that is normal. Does it stay on is the question, would like to help but still unclear to me what you're saying
Aug 13, 2011 | Heating & Cooling
I have horizontal lines in black and white on the whole screen and tv will not turn off manually,the tv is an ilo 42 inch plasma.I only selected IBM because ilo was not listed
The problem is in the vertical section of your TV.Ethier it is loose connection or leaked capacitor or deffective vertical ic.Try to resolder first the vertical section.If did not work replace leaked capacitor around the vertical ic,then check the 12 v dc supply of vertical ic and final ok the rest is good replace vertical ic.
Jul 16, 2011 | Televison & Video
Blank screen except for a single horizontal line through the middle of the screen.
Hello
Your TVs vertical swee sction has failed. All CRT based TVs have both vertical and horizontal sweep sections to sweep the picture both in vertical and horizontal direction to display it on the picture tube screen. This process is otherwise called as scanning. If vertical scan section fails, you will see a horizontal line at the middle of the screen and if horizontal scan fails, you will see a vertical line on the middle of the screen.
You have to open your TV to retify this fault, as the fault lies in the internal circuit board. Open it after disconnecting it from the mains wall socket, and locate the vertical output section inside. It is very easy to locate. On opening you can see a coil fitted on the neck of the picture tube, called deflection yoke, and there will be four wires from it goes to the main board. Out of which two of them will be thick, and the other twos will be thin. The thick wires are usually colour coded as red and blue. Just follow the two thin wires. You will reach to a plung in socket to which these four wires together connected. Turn upside down the circuit board, and follow the print track through the print side of the above said two thin wires connection goes. it will go to the vertical output section.
Before doing any thing, first look into the circut board for any loose or bad solderings are there. It is a common fault that this section have loose solderings on it, because most of the components will heat up while working. Repeated heating and cooling, make loose soderings to emerge.
Resolder all the suspected points, as loose solderings will be microscopic,a nd acnnot be detected very easly. We in the service field also will fist do this.
Usually vertical output section is composed of an IC related circuit. Solder all pins of that Ic first and feel the effect. If this does not help, desolder the IC out of the board, will be screwed on to a metal heatsink, go for the same type and number. Replacing the IC will solve your problem.
If you wants any more assistance, feel free to contact me through Fixya. OK.
Dec 09, 2010 | Toshiba 32A30 32" TV
I have a good picture then it goes horz. with static and then a good picture and then a horz. lines and static about every sec.
The horizontal line indicates failure of vertical section, checkout the output capacitor of vertical-section connecting to the yoke (vertical) for any loose contact, dry solder, capacitor wear-out.
Need to check the register and filter capacitor that powers the vertical-section.
Sep 28, 2009 | Sanyo DS25390 TV
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
27"tv sharp analog
Good day.
Refering to to mr walts inquiry and if it is, maybe you are having some issues in your vertical circuitry. It may be loose that it needs to be resoldered and other filter capacitors within the vertical section.
chris
Mar 22, 2008 | Sharp 27C-240 27" TV
Vertical line up and down middle of TV screen
i think this is the called picture in jail. this might be due to 1 power supply reg.poor or filter cap dry. 2 loose or dry joint nera hor. output section or capacitor in eht section.
Sep 21, 2007 | Mitsubishi CS-35505 35" TV
JVC 31" TV Vertical Screen Jumping
I've heard this is could be a cold solder joint and am looking for advice on which IC to re-solder. 1 whatever you have heard is correct as whenever you smacked the lelt side it works fine. 2 you will have to check loose contact in vertical section. your vertical ic might be located at the left side of the tv. 3 check any connector is loose near vertival section. 4 any preset is loose in vertical section. it is a simple problem if you are not technical person please get it done by tech person. as your tv is old & if it is done by tech person tell him to replace all elrctrolytic capacitors in vertical section. good luck.
Sep 20, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Ekse
