Need a part # and where to order a horizontal output transistor. stamped on transistor p5nk 50zFP GK180 CHN 607
    Scholar:
  • 104 Answers
The part number is P5NK50ZFP, but this is a Power MOSFET not
an Output Transistor. The FET can be obtained HERE
Posted on Mar 12, 2008
  • 5,138 Answers
Hori out puts numbers are like D1581, C1551,or NTE2973 NTE2324 and so on None of the numbers you have cross over to anything.
I loss the horisontal regulator of my philips tv with 25pt463a/7ir model
Hello
You are talking about the horizontal output transistor damage I assumes and post this solution. If LOT has internal winding short, the horizontal output transistor will get shorted. It will be best to replace the horizontal output transistor, alongwith the LOT
Mar 03, 2012 | Televison & Video
Onida 21''ctv picture coming in stamp type {cutting from four sides}
Hello
Replace its Horizontal output Transistor. If the base-emitter junction has a leak inside it, this type of fault will occur. Before replacing it, check the main DC voltage to LOT [Line Output Transformer]. It should come around 102VDC. If there is not this much voltage, check the electrolytic filter capacitor connected across thie supply line to main negative for open or value developed. Replace the same is good. Till there is low voltage found, check the retifier diode that rectifies this 102 volt DC. If all the above are OK and still you get a stamp like raster, check the heat of the Horizontal Output Transistor described above. if it overheats, LOT is defective and should be replaced with same type and number. OK.
Jun 12, 2011 | JVC Televison & Video
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
Hi My toshiba CX36H60 has a problem -- no picture but sound is good. what could be the issue and how to rectify it. Please suggest.
As sound output is ok, main board is correct with respect to sound output, video IF and ther stages. The fault lies on the horizontal output section. It may be LOT fault. Check it further for horizontal oscillator stage, and horizontal output stage. Check the collector voltage at the horizontal driver transistor. If you have a frequency meter, check the frequency of that point. It should be somewhere near 15625Hz. If the frequency there is Ok, then proceed to horizontal output stage. Check the horizontal output transistor. If it seems to be faulty, replace it with similar type and number. If the replaced horizontal output transistor heats abnormally within seconds after swich on the set, surely LOT has troubel. Replace it also with same model mumber and type.
Oct 16, 2010 | Toshiba CX36H60 TV
How shrink picture size in AKAI 14" portable TV
Less power output from the internal SMPS; usually 110v, may less. Horizontal output capacitor may leaky. Horizontal output transistor fault may occur. In rare cases deflection yoke assembley fault.
If the picture is stamped size; suspect the power supply. If the picture is less in width, suspect the above said capacitor, and the lenearity coil fitted on the main board.
Oct 13, 2010 | Akai LCT0510 5 in. Portable TV
32gt660 (ctc187cn3)
The flyback is availabel as part number 223952-rep from tritronicsinc.com at a cost of $29.00 US.
Please replace the horizontal output transistor wih the correct one as well: Part number 223942 available from above at a cost of $15.49
Dan
May 20, 2008 | Sony KV-32FS13 TV
Fuse blows, Disney DTD1363
It look like this is the PN p5nk50zfp.
This site has your part. Data sheet
This part, it might be your voltage regulator not the horizontal output transistor.
Good Luck.
Mar 12, 2008 | Disney DTD1363-CAR 13" TV/DVD
Disney DTD1363-car, Need part # of transistor
The tv keep shuting off an the dvd door won't open. I have model # DTD1363-CAR
Is there any recall on the tv
Horizontal white line
Verticle output transistor. It will be mounted to a heat sink. t should have Verticle stamped on the circuit somewhere near the Transistor. Locate the numbers on tht Tansistor and let me know what numbers and letters are, and i will post a link to where you can buy a replacement.
Jan 22, 2008 | Jwin JV-TV1010 5.5 in. Portable Television
Sony KV-32S40
When the horizontal output (2SC4927) is shorted it means one of 2 things is wrong - the horizontal drive transformer has cracked solder joints or the flyback transformer is shorted inside. If the solder joints on the horizontal drive transformer (the small grey transformer connected to the base of the horizontal output transistor) are cracked then the set will play for a little while and then the parts you just replaced will again be destroyed. ALWAYS resolder the driver transformer when replacing the parts you mentioned! When I replace the parts you mention and I do not see any obvious cracks on the driver transformer then I unsolder the B+ pin of the flyback (labeled 135, for 135 volts) and put a 60 to 100 watt lightbulb (drop-light) in series with the flyback. This means that the 135 volts B+ goes through the lightbulb and then into the flyback, so the lightbulb acts as a current limiter to protect the horizontal output. When you turn the set on the bulb should glow no more than about half bright and you should hear the high voltage come up, but you should not see a picture. If you turn the set on and the bulb glows as bright as if it was plugged into the wall then you can bet that flyback is shorted and must be replaced.
Jul 12, 2007 | Sony KV-32S40 32" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
