Question about Bosch 24 in. SHU43 Built-in Dishwasher
Getting to the control panel
I have the door off but know I can't get to the control board What is hold it in place? How can I get the front control panel off that is covering the control board? I don't want to force anything for fear of breaking something.
  • dsarthur Mar 12, 2008
    I got it all put together. Thanks for the help.
    Novelist:
  • 131 Answers
The outer user interface / touchpad stays in place. it can be removed only after removing the electronic machine relay board. The relay board is accessed from the inside of the door. You need to separate the inner door panel from the outer door panel. After removing the screws from around the inside of the door, the inner panel should lift up and away from the outer panel. The plastic cover should just clip on. you may need to use a flat screwdriver to release one or more of the clips. After that you'll be able to see any screws or clips holding the relay board in place.
Posted on Mar 12, 2008
  • Michael Grimshaw Mar 12, 2008
    Oops, sorry. I responded for a GE dishwasher in my last post.
    I've only changed a Bosch electronic control a few times, and they were all different. What I remember is, they use a lot of clips, and it's not easy to get the electronics loose. Try looking at the new piece to see where those clips are, and be persistent. Sometimes you can get the metal bracket loose from the door to make it easier. Also, you could remove the wires to get them out of the way. I'm pretty sure they're keyed, so it's hard to put them back in the wrong place.
    I remember having a lot of difficulty with a couple of those.
  • don8734
    don8734 Mar 02, 2013
    FYI: You have to release some clips on the OUTSIDE/FRONT of thecontroller and push it through INTO the cavity. Then it takes some finagaling to pull it down and out.
How do I get to the motor control board
Remove front panel by undoing screws that hold door on, pull top of panel forward, lift up & remove. Motor control board is on the Lower rhs.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
Dv209aew/xaa where is heating element
Under the drum on the right hand side. To get to it you will need to remove the top panel. UNPLUG it. take out the 4 screws that hold the control panel in place. Take out the three screws that hold the Main control board( on the lefthand side). Unhook the control board connectors from the main control board. Remove the control panel. Take off the 2 bottom screws inside the door, take off the 4 screws that hold the front cover plate. Take off front the front cover. Take off the 5 screws that hols the drum plate. Remove it. Remove the belt, and the metal bracket on top. Take out the drum and you will be able to access the element.
Jan 30, 2011 | Samsung DV218AEW Electric Dryer
Kenmore washing machine Model 970C45072-30 spin cycle does not work. what could the problem be.
I had a problem where the water would fill and do everything except when it came to spin it would not work. I took the back cover off and checked gave some wires a shake and found that a spark came from the motor control board. Took the board out and inspected and found that a solder joint on a thick metal jumper was broken (eroded). Reflowed the solder joint with a soldering iron and added some more solder for added strength. Plugged the board back in and I was up and running. Always do a visual check before doing any repairs, it may save you a lot of money with a quick fix like this. This may look complicated for some but it's worth trying. A repair tech told me either its the motor control board($150) or the motor($300). I would have spent over $500 plus his labor....5ccef753-244a-4024-8152-27b78ddbb7b9.jpg
Sep 01, 2010 | Kenmore HE2 Plus Front Load Washer
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
I know fuse is gone on Maytag MAH7550AGW but how do I access the motor control board? Which screws do I need to remove etc?
8 screws inside lip of dryer door including door hinge screws the hold front panel will come off the control board will be bottom right front.
Sep 28, 2009 | Maytag Neptune MAH7500A Front Load Washer
I don't know how to turn on the door panel
I had same issue. The control panel had been set to Sabbath mode. Hold down the "DOOR ALARM" button for 3 seconds. Then lights will turn on on both display windows. Scroll using the + and/or - sign on the left side display until "SAB" is shown. Then scroll using the + or - sign on the right side display until OFF is shown. Finally, hold the "DOOR ALARM" button down again for 3 seconds. All should be good to go!
Aug 29, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Lx30h hobart dw. booster will not turn on. element good,hi-limit is good, changed temp probe, still no power to contactor
The booster heat control circuit is controlled by the relay board. Visually check for loose or burnt relay contacts...
You will see the booster LED light when it calls for heat. Some newer machines have a second high limit on the right hand side of the booster tank.
It may be your control board is configured for low temp with no booster. When you power up, the display should say LX30H. If not
Pull open the upper drawer, place a magnet over the door interlock switch.
CAUTION, 220 volt power is present. be carefull what you touch.
on control board, short J5-1 and J5-2, then power up. You are in factory setup. press select on the control board to see each option on the front panel., press up arrow on control board to step up through options for each step. when done, press the off button on front panel. remove short and start up normally. With the magnet in place, AND THE DOOR CLOSED, run the machine and observe the relay board status lights.
If you want to adjust the temp set points, with the machine off, press and hold the hidden key behind the front panel logo, and press select on the control board.. Or on power up, hold the wask key..Same to adjust options as above. Press off to exit.
Jul 04, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Torn gasket
Catriver(fixya) has a solution:
Remove the top, by removing the 3 screws in the rear. The top will slide off toward the back. Next remove the control panel. Remove the 2 screws on each end on top. Remove the detergent drawer. Remove the torq screws behind the detergent drawer. The control panel will now snap off, pulling from the top and lifting up. Once freed, remove the control panel ribbon cable from the side of the main board. Now remove the screws holding the door switch mechanism in place. Remove the spring that holds the outer part of the boot from the front panel. Now remove the 4 quarter inch screws that hold the front panel and door on the front. Now you can install the new boot with ease. I know it sounds like a lot, but it is not that bad. Just reverse the process when the boot is on the tub. Make sure to have the mark on the boot ^ lined up with the mark on the tub on top.
Apr 14, 2009 | Kenmore 44072 Front Load Washer
Kenmore HE 2 Front Load Washer Leaking
Remove the top, by removing the 3 screws in the rear. The top will slide off toward the back. Next remove the control panel. Remove the 2 screws on each end on top. Remove the detergent drawer. Remove the torx screws behind the detergent drawer. The control panel will now snap off, pulling from the top and lifting up. Once freed, remove the control panel ribbon cable from the side of the main board. Now remove the screws holding the door switch mechanism in place. Remove the spring that holds the outer part of the boot from the front panel. Now remove the 4 quarter inch screws that hold the front panel and door on the front. Now you can install the new boot with ease. Just reverse the process when the boot is on the tub. Make sure to have the mark on the boot ^ lined up with the mark on the tub on top.
Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
How do you get the front panel door off?
three screws behind kick plate remove,them two screws holding on doorlock remove them, remove outer clamp on door boot,pull panel from the end near were kick was,some of those machines have 3 more screws behind control panel? see how you get on and let me know . close Ireland bye for now!
Nov 22, 2007 | Kenmore Elite 45986 Front Load Washer
Bosch 24 in. SHU43 Built-in Dishwasher Logo
210 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
