15 to 16 is most likely the right point gap,a dwell meter would be better if you had one,30 on the dwell.I work at napa,they can go on line ,mitchel on demand,and get the exact specs for you.
.016 i believe it is. then after you set points you will need to check timing. a change in point gap alters the timing
use a dwell meter, set the points to 28-30 degrees of dwell.
