my 66 squeals on talkback i have to cut the mic gain down to about 12 o,clock to stop it is there a way to cut down the squeal on talkback without having to turn down the mic gain so much
Comments:
Mar 12, 2008
- ok thanks a lot ..i,ve actually got a astatic 636 mike somewhere if i can find it,will have more to ask you about on a galaxy 44 and mirage 88 when i get to them,thanks
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume. ****** Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback
just amplifies what goes to the RF section. Try adding a 470k ohm
resistor from junction of C155/R207 to the junction of C187/R235 on
the solder side of the board. This will also give you clean talkback on
SSB and FM. Try different values of resistance to get the amount of
volume you want. The less the resistance the louder the talkback will be.** Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down. Let us know,,, Mechanic
I have "talkback" installed on three of my radios and all talkback is, is a resistor soldered onto the bottom of the board. All you have to do is CHANGE THE EXISTING RESISTOR TO A SMALLER RESISTANCE. I'm NOT a tech and can't say which one but if I was you, I'd take it to a repairman/tech and ask him what size he recommends. Or you can try a "variable talkback" that limits the volume. CHANGE THAT RESISTOR.....SHE'LL WORK "JUST FINE".
Was this helpful?
Yes
No
Solution #4
posted on Oct 09, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Disabling Talkback Disconnect wire located in J15 no more squeals
uniden UHF model UH016 continuous tone and flashing channel number. Wont do anything while this is...
(More)
uniden UHF model UH016 continuous tone and flashing channel number. Wont do anything while this is occuring.
i just set up a gme electrophone tx830n but all the led lights stay on all the time and no noise...
(More)
i just set up a gme electrophone tx830n but all the led lights stay on all the time and no noise comes out of speaker
i have pulled the wires out of a maxon mic from a whelen 295hfs1a siren it has six prons 2 black one...
(More)
i have pulled the wires out of a maxon mic from a whelen 295hfs1a siren it has six prons 2 black one white and one red
I brought a Bluebird Sylphy recently and the car came with a DM 306 - PW706 radio with most of the...
(More)
I brought a Bluebird Sylphy recently and the car came with a DM 306 - PW706 radio with most of the display in Japnaese. 1. Can the display be shown in ENGLISH instead of Japanese. 2. Where can get I copy of the manual for the radio 3. Can the device play DVD's
