Home | Canon | PIXMA MP160 All-In-One InkJet Printer | How to reset the ink lev...
Canon PIXMA  MP160 All-In-One InkJet Printer
Problem for Canon PIXMA MP160 All-In-One InkJet Printer
How to reset the ink level monitor on Canon Prixma MP 160
By Tony Tran on Mar 12, 2008
After the ink cartridge for the Canon Prixma MP 160 have been refilled and test then I press the button Stop / Reset several times but unfortunately the problem low ink indicator is still remaining as before although I have done as some user online suggested. Please tell me what to do the correct steps to resolve this issue.
Same Problem
Jan 28, 2009
-   I am having the worst time trying to reset my canon mp160 ink level after I refilled both cartridges. I have tried every method of "hold the button down etc..." as well as trying to download mptool, but to no avail. Could someone please let me know if my hunt for a solution should continue? thanks so much! Liz -   singsing
Jul 13, 2008
-   when I put in a refill cartlidge the colour light stays on , how do I fix this.-   bertmain
Best Solution
posted on Jun 16, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Desconectar del toma corriente el impresor
Mantener presionado el botton de power mientras se conecta al toma corriente
Manteniendo presionado el mismo boton de power presionar dos veces el boton de reset (circulo con triangulo rojos)
Soltar el boton de power
La impresora se tardara unos 10 segundos en mostrar el vaor numeroco de cero.
Presionar + para que el valor se mueva de 0 a 1.
Cuando el valor este en 1, presionar el boton que esta a la par de reset, de esta manera se encenderan dos luces
una es la de plain papaer y la otra de photo paper, en este momento se coloca papel en la impresora
Se presiona el boton de power una o dos veces (da igual), la impresora imprimira una hoja de prueba
Al imprimir esta hoja el valor en la pantalla regresa al valor de cero, dejarlo asi
Abrir el scan cover (para sacar los cartuchos pero no se sacan), con la tapa abierta desconectar fe la energia al impresor
Sacar los cartuchos, cerrar la tapa y encender el impresor.
Volver a colocar los cartuchos ya refilados en la impresora y LISTO.
Solution #2
posted on Mar 27, 2008
Helpful)
cropp
Rank: Guru  Canon Expert
Rating: 87%, 561 votes
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Was this helpful?
Yes
No
Solution #3
posted on Dec 31, 2008
Somewhat Helpful)
ziee
Rank: Apprentice
Rating: 80%, 5 votes
go to this link http://canonresetter.co.cc/MPTool-to-reset-MP150.html
download the software and follow the instruction
it's work fine for me
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Nov 09, 2008
Somewhat Helpful)
nlife
Rank: Apprentice
Disconnect the printer's outlet
Hold the Botton of power while connecting to the outlet
Holding down the power button pressed twice the reset button (red circle with a triangle)
Release the power button
The printer takes about 10 seconds into the show vaor numeroco zero.
Pressing + to the value moves from 0 to 1.
When this value to 1, press the button that is on par with reset, this will light up two lamps
One is that of plain papaer and the other of photo paper, at this point is put paper into the printer
Pressing the power button once or twice (it does not matter), the printer will print a proof sheet
When you print this sheet the value in the display returns to zero, leaving it well
Open scan cover (to remove the cartridges but was not removed), with the lid open faith disconnect the power to printer
Remove the cartridge, close the lid and turn on the printer.
Re-positioned and Refill cartridges in the printer and READY.
Comments:
Nov 09, 2008
Was this helpful?
Yes
No
Solution #5
posted on Mar 16, 2009
Somewhat Helpful)
ksdi
Rank: Wiz
Rating: 81%, 26 votes
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
273
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MP160 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP160 All-In-One
Do you recommend Canon PIXMA MP160 All-In-One InkJet Printer?
Answer
Answer
i have placed new cartiredges in my printer after giving one print out it shows error ink observer... (More)
Answer
De Printer functioneert naar behoren doch het Scannerstuurprogramma meldt steeds dat de kabel slecht... (More)
Answer
it is giving me a paper jam error but there is no paper jam and i can't get it to let me do... (More)
Answer
Hi, I cannot scan with my canon MP160, when I am trying to this the error is coming up with number... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA MP160 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 482
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
