Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Whirlpool silent partner 1 model du1055xtps
One day it worked great, the next, nodda.checked breaker,good, ckecked power at junction under washer, good. if i remember right , one day i had to push on the front a little harder than usual to make it have a diplay. any ideas
  • abcmagumps May 12, 2008
    DW does not operated. No lights on control panel. Checked power supply and power connection to DW. After a few days start delay light occasionally blinks with door closed.
  • BrooklandDC Sep 14, 2008
    In our case, though, the washer stops mid-cycle.  Again, we have checked the wires and even replaced the circuit breaker this morning.  It started up this evening, then stopped.
    President:
  • Whirlpool Master
  • 2,651 Answers
Possible you have abad door latch switch. open the door you should be able to "trip the swithc by inserting a small ***** driver ,into the latch opening. essentially simulating the door closing. you should hear a click of the microswitch asyou push on it up and down. theres also an electronic fuse located on the control board itself. requires taking panel down. white rectangle mounted on electronic box with 2 black wires leadiing to it. part number 8193762. comes with instructions if needed
Posted on Mar 13, 2008
Is there a fuse for power windows?
According with the Ford Owners Manual (page 226 and next) I suggest to check the next locations:
- Battery Junction Box fuse # 6-60AMP will feed Central Junction Box ( under driver side)
- the inline circuit breaker #47-30AMP, through the Accessory Delay Relay, powered by fuse #17-15AMP to the Window Control Circuit.
Check the fuses, and for 12v at the points. Then check for 12v at the driver side door switch pannel.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | 2002 Ford Explorer
Dishwasher did not complete last cleaning cycle. There is undrained water laying in drain pan, and pushbutton switches are not responding...as if power was shut off. I am a retired home builder w/many...
Hello, welcome to FixYa.
Based on your description and the model being a Whirlpool DU1055XTPS there is indeed an internal "fuse" or as Whirlpool refers to it, "thermal fuse" or "bimetal". I'd suggest you likely have a faulty thermal fuse in the control board, but it is not resettable unfortunately.
It's pretty easy to replace or to check, I've attached a link below to change the fuse, but you can also use the link to access the thermal fuse to check it.
With the aid of an ohm meter, (**and the electricity off...safety first**) remove one wire and measure across the two contacts and it should show continuity, otherwise it's open and therefore no good.
The part is available at most brick & mortar part places or on-line at vendors such as "repairclinic.com" or searspartsdirect.com" to name a couple. Part number 8193762...looks like this image and retails for about $15-$20USD based on the model you provided.
This is the youtube link to help with the repair "how to".
http://www.youtube.com/watch?v=jdlVbTXm8SY&feature=player_embedded
Let me know how you make out or if you require any further assistance and I'll try to help in any manner I can. Good luck.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 10, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Is there a fuse box on the whirlpool partner ii.. my drain was clogged and now there is no power to the dishwasher
Hi, Try checking the circuit breaker to see if it tripped. If not, did you maybe unplug it from under the sink by accident? Check this and let me know. Good Luck, Shastalaker7
Nov 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
No power to Selections, Water Did Not Drain
When you remove the bottom panel cover, check the wiring connection inside the junction box on the right for a loose or shorted wire.
If that's ok, open up the console and check the continuity of the thermal fuse that's clipped to the control board. Chances are it needs to be replaced.
Mar 05, 2009 | Dishwashers
Whirlpool gold quiet partner iv will not turn on there is no sign of life in it at all.
Hi chrslndsy,
I'm Harvey the Master Plumber.
Your problem is: whirlpool gold quiet partner iv will not turn on there is no sign of life in it at all.
Usually this indicates that the power is disrupted. First check the breakers. 9 times out of 10 it's a broken, loose or burnt connection in the d/w junction box. It's located underneth the d/w behind the kick plate on the right or center, depending on model. Turn the power off at breaker and remove cover. Take each wire nut off and repair/replce as nessessary. Test before you close it up.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Washer shows no signs of power
Yup, this is what happened to me. I also get a "44" error code and erroneous beeping. This is exactly what the class action law suit was about. The Whirlpool Calypso's of your type have the red LED and touch controls, right? They go bad internally after a few years, regardless of how much or how little you use them. There is nothing you can do. Order a new or reconditioned control panel, or have it serviced and repaired by a qualified company referred by Whirlpool Service... Don't do this yourself... The part is about $200 or so plus $60 to $80 minimum call out charge, and sometimes the new parts are as bad as the one you currently have. Best Bet... Time to upgrade to something newer. You may spend your money on this repair, yet in a few months, have the same thing again or something else go wrong. It's just not worth the repair.... Indy :)
Sep 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
308 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
