Back to:
Tags:
Jenn-Air JED8430 Electric Cooktop
Jenn air model JED8430bdb
posted by clintbb on Mar 12, 2008
I have a question similar to the one you answered a few months ago. My cooktop has a red, a black, a white, and a green wire. From the circuit breaker I have a black, a white, and a bare ground wire. How do I hook up the wires? I connected black and red to black, white to white, and green to ground but the burners don't get hot and the fan runs about 30 secs and shuts off.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 25, 2008
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2403 votes
A similar concern on a different model (8230):
To my knowledge, the:
green - ground
white - neutral
black - 120 to ground
red - 120 to ground but between red & black, it should be 240. A Jenn-Air JED8230 requires a 3-wire, 120/240 Volt, 60 Hz Outlet.
Pls consult/confirm with your local electrical utility/codes the availability/applicability of this power/wiring system or reference National Electrical Code, NFPA No. 70
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on jenn air model JED8430bdb:
I don't want to Accept this solution
Can you Help with these Kitchen Cooktops problems?
Only the right front (large) burner operates. The lights...
I just found in a two-inch hairline crack curving along...
electric breaker tripped, attempted to reset and observed...
I have a gas cook top from Jenn-Air..It is abt. 16 yrs old...
Loading problems.
Repair Service
Find Kitchen Cooktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
