Question about KitchenAid KCMS145J Microwave Oven
KitchenAid KCMS185JSS1 Door Removal
I have a KitchenAid KCMS185JSS and have a new entire door assembly to replace because when the unit was installed the SS door got dented up.I cannot get the old door off of the hinges, please help, Thanks.
  • pj22burdi Jan 23, 2009
    would like to remove & replace the door
  • 413 Answers
On most new MW ovens, the door will lift off the hinges once the top grille is removed. There are two screws on the top that hold the grille in place.
Posted on Jun 15, 2008
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
How do you take off a microwave door and put a new one on?
KHMS155LSS0 - May 27, 2017
On many models you can open the door all the way and gently lift it off.
Otherwise, you have to do some disassembly.
The support page for your model, with manuals, is here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 27, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
J KP85W0D1WW microwave door liner on inside is falling out. Is it possible to replace door?
yes you can replace the door assembly,but it will be as much or more than just replacing the entire unit
Jan 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for replacing door handle on kitchenAid microwave oven model KHMSi55LSS0
Remov fan cover, bottom plate, you can either do it right and pull out the entire plastic baffle to reveal the hindge bolts or you can just jam something between just enough to get a long socket on a small socket wrench. You must replace the entire door. Trying to replace just handle is almost impossible.
Feb 13, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
Looking to replace the plastic piece on the vertical edge of the door (handle side) on my Kitchenaid Microwave/Hood combo khms145kss1. Is it possible to just replace this instead of purchasing the entire...
They don't show the entire door assembly as being available.
But you can replace the outer door frame (outer door panel)part number 8184319.
At $167.94, it's not cheap. But you can get it here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 29, 2009 | KitchenAid KHMS145KSS Microwave Oven
KitchenAid KCMS145J Microwave Door Latch Broke
I downloaded a parts schematic of the door latch assembly and thought I would determine the broken part, order a replacement and install same. As soon as I started to remove the shell of the unit to get at the latch assembly, I discovered non-standard fasteners are used. My wife advised me to stop and take it to a service center because she did not want me to mess up the containment of the radiation! Thanks for your interest. MB
Sep 04, 2009 | KitchenAid KCMS145J Microwave Oven
Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Sep 03, 2009 | KitchenAid KCMS185J Microwave Oven
How do I replace the door handle on the khms155lss model? Cannot figure out how to dismantle the door
Visit this web site www.applianceaid.com enter your model number then scroll down to your part. Click to enlarge exploded diagram and view the entire diagram for exact assembly. Now you have information you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 13, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KitchenAid KCMS145J Microwave Oven Logo
350 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Marcus
Level 1 Expert
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
