Question about Whirlpool Calypso GVW9959K Top Load Washer
Won't spin, codes coming up
Ld and ob
  • 2 more comments
  • remirenuad Aug 24, 2008
    mine does not even sound like the pump is coming one - how can i test the pump to see if it is still functional?
  • Anonymous Aug 25, 2008
    Washer has no spin, makes a humming noise, wont drain, water on floor
  • kippy122953 Aug 25, 2008
    Code LD, washer wont drain, makes a humming noise, water on floor, wont spin.
  • Anonymous Aug 26, 2008
    water is leaking from top of whirlpool calypso washer. all over floor. won't always spin. shows LD and OB.
    President:
  • Whirlpool Master
  • 2,651 Answers
Ld=long drain..... ob= out of balance.. both related to not draining quick enough, therfore spins with too much water thowing it self off bal. ever have any problem with this machine. heres what i can suggest. tip the machine back and remove 3 5/16 screws holding bottom panel on . on the right side approx 2/3 of the way back is the pump assy.( a yellow and black hose going to pump. are there clips on the pump hoding it up to the pump motor???if so yuou can realease the clips and diconnect the hoses lookin for lint build up in pump itself.WARNING!!! you will ge wet ther is ALWAYS water indide this pump especcially if you not pumping out correctly.i use a large black trash bag under to catch water.sounds like a clogged drain pump. they have a replacement for this particular pump. itcomes as 1peice now pump and motor, bigger ports to prevent lint build up, easy enough to replace if needed. sounds like aclog fro sure though good luck
Posted on Mar 12, 2008
Caution: if your wife uses wired bras, the wire may come out and get stuck in the drain from the top allowing it to collect lint and clog. ask her if any of them have been missing the wire, if so then that is probally the problem and you must take the tip of the tub off to get it out with some mechanical fingers. if not then the clog might be underneath in the pump or drain housing. good luck.
Posted on Mar 19, 2008
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
Whirlpool Calipso model clothes washer shows a LD and doesnt run
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have the error LD and OB also wont do spin or rinse cyles
The "LD" code or "long drain" indicates a pump/drain related issue. Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure the impeller has no broken/missing blades and that it spins freely. If any blades are missing/broken or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer LD and OB codes - Controller issue?
inside the front panel there should be a pouch with a multi-language guide in it, it will tell you how to run a diagnostic troubleshoot with it.. i got mine a few days ago, its former owner said it woudln`t drain and would shut down, i came to find the "pump" that the tiny seperate motor spins underneath had a hair tie stuck in it.. after i removed the pump assembly and filled it with alittle canola oil to make it spin alittle more free, i removed the hair tie and its been workin like new since.. shame the lady who gave it away to me didn`t care to take the time for someone to come fix it..
Apr 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD and OB on Calypso
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating
pressure switch resets.
Press STOP/CANCEL to clear the display.
OB:
If the motor controller detects an unrecoverable off-balance condition, the machine controller
will shut down and display an “ob” for off balance.
The lid switch must be opened at least once before restarting the cycle, if this condition
occurs. Opening the lid will allow the customer to view and redistribute the load.
Basically, it sounds like your drain pump is bad or clogged, and the extra water is throwing the spin cycle off balance
-Perry
800-Appliance San Diego
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Dec 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob codes
LD code means your pump is cloged with lint or small piece of clothing such as a sock. I had the same code on my washer and sure enough i found my pump cloged with lint from a blanket my wife washed. hope this helps. sorry I cant help on the other code.
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Whirlpool Calypso GVW9959K Top Load Washer Logo
150 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
