Question about Amana AFD2535DES French Door Refrigerator
Amana French Door Bottom Freezer
Ice maker on Amana French Door Bottom Freeze won't make ice.
    President:
  • Amana Master
  • 2,651 Answers
See if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Posted on Mar 12, 2008
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Samsung RF266AEPN
Amana fridge. french door ice maker now seems to freeze overflow of water so i'm using hair dryer frequently to remove the clog. why is this starting
Your defrost assembly has probably stopped working, which means that you are probably also building up ice in between the panels.
Jun 06, 2011 | Amana AFI2538A Bottom Freezer French Door...
Not making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 24, 2010 | Amana AFI2538A Bottom Freezer French Door...
The ice maker is currently working. We don't have anything obstructing it in the tray. Periodically it works, but not for long.
heatman101
dyj56
Sep 25, 2010 | Amana AFD2535FES Stainless Steel Bottom...
Ice maker stopped working aman abd2533deb
heatman101
Sep 17, 2010 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Our Amana French door ice maker is clogged with ice chunk about 2-in x 6-in and we can't pull it out. The area is too small to pour hot water in onto the ice. Any suggestions?
Good day,
What you have described sounds like a defective water valve on the back bottom rear of the machine. It will need to be replaced.
Although awkward, the best way is to remove the ice maker completely and let it air dry, while the valve gets changed.
The above diagnosis is based on the fact the freezer is maintaining it's normal temperature. If for some reason the freezer thaws and then refreezes that problem would need to be addressed first.
May 26, 2010 | Amana AFD2535FES Stainless Steel Bottom...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Amana bottom freezer not working on model abb2524deq
I replaced the solenoid and my ice machine starting working again.
May 02, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Amana AFD2535DES French Door Refrigerator Logo
291 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
