Question about Hotpoint HSS25GFP Side by Side Refrigerator
Whinning noise Can you please tell me how to remove and replace the evaporator motor. Thank you
  • 828 Answers
Evaporator fan motor is located in the freezer compartment behind the back wall. To access it you must remove the shelves and the back wall which is held in place by screws. Then you can remove the old fan motor and install a new one in the reverse order that you used to remove the old motor.
Posted on May 23, 2008
Whinning noise when acceration. Engine accelarates fine but there is also a whinning noise
check alt bearing,open hood & listen while running,turn off engine and remove drive belt then start engine to see if noise goes away.
Jul 10, 2014 | 2008 Jeep Compass
Loud whinning noise
sound like transmission oil pump noise if you hear noise when vechicle accelerating moving.
Jul 29, 2013 | 2003 Mercury Mountaineer
Agitator only moves a little bit and making noise
Most likely agitator dogs / gears are stripped out inside agitator. If it's a double action agitator where the top turns independently from the bottom, the top should turn one way and not the other. If top of agitator turns freely in either direction, then replace those dogs. If it's a single action agitator, then grooves that slide onto transmission shaft in agitator itself could be stripped out. If that's the case, replace agitator
Oct 27, 2017 | Kenmore Series 70 Washer Motor 387780
Motor noise
tight a little the drive belt, and test and replace the belt if necessary.
2) test the bearing motor and repair.
3) LUBE the deck belt and rollers bearing and replace if necessary maybe you have a WORN deck belt with noise!
God bless you
Nov 21, 2012 | Treadmill Doctor Proform Sport 1100...
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
MOTOR NOISE and noise stopped after closing the fridge door
Hello
Is the noise on the inside or the outside? Most often noise is caused by one of the fan motors going bad.That being said. If the noise is on the inside it's the evaporator fan motor. If it's on the outside in the back then it's the condenser fan motor.
I hope this helps you. Please leave feedback.
Thank you.
Aug 24, 2010 | Refrigerators
My Lg Diswasher is making a dry whinning noise all the way through while motor is running How can i tell if its the motor or the impeller Kim
The problem is indeed in the wash motor bearing.
unfortunately most motors come with complete with impeller.
You didnt mention model number so unfortunately i cannot give you a re[placement cost.
Regards
aardvark Repairs
aardvark.repairs@btinternet.com
Nov 17, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Very loud clicking noise from my LG LSC26905TT refridgerator
first you have to remove all shelves in the freezer,then remove all screws in the interior rear panel. In some cases you'll have to remove a couple of shelf tabe located on the side wall. Once tha panel is removed,the fan will be in plain sight. The blade is usually aboue 4-5 inches in diameter and is attached to a small motor with 2 wires and a green grounding wire. Note: you might want to check why it's making noise. Is there ice built up around the blades?Are you getting too much moisture entering the box thru faulty door gaskets?
Aug 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Noise in my refrigerator
Replace the evaporator fan motor that will solve the problem
Nov 29, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerator making a whinning noise.
sutty, you have a 2 speed DC evaporator motor in this model. There should be at least 60 seconds between any fan speed changes. On the back side of the refrigerator you have a main board. Unplug J2 connector on the board. Check for 13VDC between pins j2-3 and j2-8, then check for 8 to 13VDC between j2-3 and j2-4. If the voltage is correct I would suspect the evaporator motor. If the voltage is incorrect, then the problem is in the main board. Pins read from left to right 1 through 8. Catriver.
Jun 29, 2007 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
144 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
