Question about Roper RES7646KQ Electric Dryer
DRUM WON't TURN on my Roper Dryer
I'm pretty sure its the belt because the motor is running. I just wanted to know if I have to take the entire thing apart just to replace the belt. I already have the casing on the back off but it seems pretty complicated to take the whole thing apart.
  • 1 more comment
  • 12134 Mar 15, 2008
    dryer comes on and hums want turn but i can turn with my hand and it will start
  • dave115 Sep 13, 2008
    I have the casing off the back,how do I get up at the belt?
  • bshepherd Oct 01, 2008
    my motor will run but i have to give the drum a push start, is my motor burnt out? my belt is not broken or fraid. please help
Thanks but now i need to know which way the tention pully points it was off when i took it apart
Posted on Oct 01, 2008
    President:
  • Roper Master
  • 2,651 Answers
You can put the back back on, remove the 2 screws under the lint filter( if ones mounted to top of machine ), then the top tips back revealing 2 5/16 screws holding the front panel on. lift off hte panel and string new belt arond drum and hook ove rht e motro pulley , first passing the belt through the idler tension pulley. belt number is a 341241
Posted on Mar 12, 2008
I have a Roper dryer res764kq2 and it will not tumble. I have taken the back panel off to find the belt is broken however I can determine how to get to the drum to replace the belt
Unplug the dryer and take it outside.
Step 1: remove the filter
Step 2: Remove 2 screws from filter chute on top of dryer
Step 3: Pull top towards you on each side slightly to raise it
Step 4: Remove 2 screws inside the front panel
Step 5: Unplug the lid switch using small screw driver
Step 6: Raise up the panel 1 inch then remove it
Step 7; Remove the drum
Step 8: clean it up and lube the roller & idler
Step 9: Remove the filter chute and clean it
Step 10: Place the new belt (341241) around the drum with
the ribbed side towards the drum surface making sure it is not twisted.A twisted belt will be ruined quickly.
Step 11: Use belt to help you place the drum back in the dryer.
Step 12: Make sure the rollers are in the groove and the felt is not tucked under.
Step 13: Insert the idler into the floor beneath the motor puller and raise up on it. Then loop the belt through the idler and onto the motor pulley.
Step 14: Turn the drum a bit by hand making sure the belt is on track and not twisted.
Step 15: Replace front panel
Step 16 plug in lid switch
Step 17 Snap down the top install the screws to the filter chute and shove the filter back in.
Step 18: Give it a dry run fer a sec to make sure it works well before throwing any clothes in there.
Step 19: Grab a cold one. You deserve it!
My Roper dryer Home Movie
Jul 25, 2012 | Roper Dryers
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
Drum won't turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Roper Dryers
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
After replacing my belt and drum rollers my roper dryer has a clicking noise as it rotates
Could be a lot of things causing it, blower wheel, motor, idler pulley, rollers. Dryers have several moving parts that could cause a clicking sound. The blower fan could be coming into contact with something. There is a motor, tensioner and a belt that turn the main drum, the tensioner for the belt could be loose thus causing the clicking noise as well.
Oct 16, 2010 | Roper REX3614KW Electric Dryer
I'm trying to figure out where part #3346 goes on a roper REX5634. Pretty simple right? But I can't find it anywhere and no where looks obvious. help! Pleeez
if your part number is correct it would be the idler pulley tensioner for the drum belt and installs right next to the dryer motor inside the units lower area to keep belt tension on the drum belt
Feb 02, 2010 | Roper REX5635E Dryer
I want to know how to put the belt on my roper dryer model is RES7646KQ2
This method works on Whirlpool,Kenmore, but I am not l00% sure of Roper, you might give it a try.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Dec 03, 2009 | Roper RES7646KQ Electric Dryer
The belt broke drum won't turn
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Jun 25, 2009 | Roper REX3614KW Electric Dryer
Dryer heat but what turn
Mar 28, 2009 | AEG T57800 Electric Dryer
Roper RES7646KQ Electric Dryer Logo
555 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
