Question about Hitachi 53SWX10B 53" Rear Projection Television
53swx10b bowed picture
After installing the Sanyo ic repair kit I have a great picture that is bowed at the top and bottom. Also, the magic focus no longer works. Any suggestions as to what would cause this?
Thanks.
    Scholar:
  • 87 Answers
Double check your work for errors such as solder bridges or incorrect resistor placement. Look carefully anywhere solder could have dripped or splattered to cause the bowing. If you entered the digital convergence mode to touch it up, you will have to re initialize the magic focus for it to function. Good luck
Posted on Mar 12, 2008
Problem with Hitachi 43FDX20B 43 in, Rear Projector TV
Install a convergence repair kit for your model should solve the issue your model uses the DP15K convergence repair kit which is available from www.tvrepairworld.com the kit contains the two ICs associated resistors and the CD with repair instructions.
Jul 17, 2012 | Televison & Video
I have a Hitachi 53FDX20B projection TV. The Red color seems to bow. I have tried to perform MAGIC FOCUS to no avail. Additionally, I took the front panel off to manipulate the adjustable knobs. What I...
problem will be either Bad resistors ,in front of the Convergence ICs or ICs and resistors need to be replaced. ICs are big black ICs and will have part number on them STK392-110 use 120s or 150s
Mats Electronics has Parts ask for Convergence repair Kit. 1-800-628-1118
Mar 01, 2011 | Hitachi 53FDX20B 53" Rear Projection...
Bowed picture on Philips 55pp9352 after replacing IC's
You must have mishandled the ICs they are static sensitive, and unless you used Sanyo ICs then you will have problems. The convergence is obviously not working so the TV will need the digital convergence board repaired or replaced, also the PIP board is suspect I have seen plenty of these tvs and believe me I earned the $ 350 we charged. These sets are very difficult to work on even for a trained tech. the best thing to do is to have a repair shop do it and you will have the assurance that its done correctly, and the work is guaranteed, That makes sense. ( I will not be able to respond to any further inquires)
Jan 04, 2010 | Philips 55PP9352 55" Projection Television
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Hitachi 50SBX78B Horizontal lines and bow
John, Hitachi site is down at the moment, if you remove the clips on the front of the IC`s you will see the numbers of the convergence ic`s, and yes they are a pain to get out, they are probably stk 392-110`s if they are the originals, you`ll have to un-solder 36 pins total to get them out, check for burnt resistors in the general area of the ic`s and replace any that are burnt before turning the set on,be sure to order a tube of "heat sink compound" to apply to the back of the new IC`s, once on the set will probably still look poor, this is normal, run the set for minimum of 15 minutes then push the " magic focus button " inside the front door panel, after it has finished running magic focus it should look great, video-tek
Feb 08, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Weird warped lines
Try the Magic Focus option on the menu.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
Too much red!
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 08, 2008 | Hitachi 53SDX20B 53" Rear Projection...
Blue shadow
Needs convergence circuit repair = replace convergence IC's,
then activate Magic Focus...............need step by step?......T.
Nov 30, 2007 | Hitachi 43F300 43" Rear Projection...
Blurred screen
unit needs convergence ic's replaced.They are stk392-150 which is an upgraded part.
Feb 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Horizontal hour glass picture
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Dec 16, 2006 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 53SWX10B 53" Rear Projection Television Logo
120 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
