Hi i have a 93 Mitsubishi model# ck35402. I was told that the pip had went out. was hoping someone could walk me through on how to remove and reroute
    Scholar:
  • 87 Answers
From the bottom of the main board locate IC 2004 between the PIP module and the tuner. Remove the jumper between pins 2 & 6, then jump pins 6 & 7. Next , pull the pip module from its socket and toss it. The symptom for a bad PIP module could be black screen, no picture, blue streaks, wavy or jittering picture.The audio will not be affected. Make sure the symptom fits the cure before you bypass the PIP. Good luck!
Posted on Mar 12, 2008
SOURCE:
93 mustang dies no apparent reason
Not sure if you fixed your stall issues but....have you looked at the pip signal on your fox mustang? My 1987 mustang gt was doing the same thing it got to the point where the car failed to start. It was the pip sensor located in the distributor. I removed the distributor and took out the pip sensor replaced it with a oem replacement re-timed the car its ran great since. I also went to the boneyard and grabbed a few tfi and installed one on my distributor most mechanics suggest you do this when you replace the pip sensor. Hope this helps someone dealing with this issue on there 87-95 mustang gt. Took me about 45 minutes
Aug 03, 2013 | Cars & Trucks
Pip won't turn off. can the pip be removed or bypassed?
Some of the older sets with PIP require only the original remote to operate or turn on and off.
The PIP board usually develops problems with surface mounted caps and there is a "modification" where traces are cut and two 4.7 mfd caps inserted which will bypass the PIP board from the set--a model number would tell me if this is possible in your set or not--you missing the original remote? Almost any Mitsubishi remote of the era with PIP controls should do the job.
Dec 02, 2012 | Mitsubishi Televison & Video
Mitsubishi 60" I believe 1997 Model
You need a new PIP module. Surface mount capacitors have leaked out electrolyte and damaged the PIP PCB.
Barneyluc
Oct 01, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi model ck35402 vertical collasp do you have a mitsubishi tech tip on this problem
IC401 (LA7838) could be defective. If you do not find the LA7838 you can replace it with NTE7039.
Good Luck.
Aug 16, 2008 | Televison & Video
Mitsubishi tv model VS6061 rear projection with rolling picture.
I know this is an old thread, but I would like to post this information in the hope that someone will find it useful.
I just finished fixing this problem on my 1994 VS-6061... the problem is the PIP (Picture In Picture) board located on the Power Signal board. The PIP board contains the numbers 530B552. I bypassed the PIP board by following the directions I found at the following link:
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/130383-mitsubishi-cs-35301-rolling-picture-problem.html
"Plug in a 4.7ufd @ 35v filter cap (+)at pin 5,(-)at pin 11. Plug in a .01ufd(any voltage) between pin 7 and 9. Just plug the caps into the socket, where the PIP board was mounted (they don't need to be soldered). Just don't let the leads from the two capacitors touch, as they cross each other. The 0.01 cap is non-polarity, so either way it plugged is fine. Basically you will bypass y-signal through 4.7u, in pin 5, out pin 11, and bypass c-signal in pin 7, out pin 9 of the PIP socket.”
The bypass requires 2 capacitors: One 4.7ufd @ 35v and one Non-Polar 0.01ufd @ any voltage.
Remove the PIP board, then plug the two capacitors into the socket where the PIP board was mounted: plug the 4.7ufd capacitor with (+)at pin 5,(-)at pin 11 and plug in the non-polar .01ufd capacitor between pins 7 and pin 9.
If there is a ground wire (possibly brown) soldered to one of the tin cases on the PIP board, then you should connect this ground wire to the PIP socket either at pin 2, 4, 6, 8 or 10 which are grounds of the socket.
This PIP board was used in many Mitsubishi televisions and they were plagued with problems...This is why many of these older Mitsubishi televisions had similar problems…
Good luck
Jul 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Mitsubishi 60603
try switching your pip to the main screen and see if the pip shows blue while the main screen works.
May 29, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi hd1080
I can't disconnect the parent v chip now it is automatically blocking stations
Feb 17, 2008 | Mitsubishi WS-55807 TV
1. NO VIDEO, BUT HAS VIDEO WITH PIP ON. CHECK C763 (1UF 50V) ON THE BASE OF Q715, LOCATED ON THE UCOM-PCB. 2. NO MAIN VIDEO, THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB. THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PART # 181P504090. (CHECK ALL 'SMD' ELECTROLYTICS AND TRACES ON PIP) 3. NO MAIN OR PIP VIDEO, CHECK C7014, 47 UFD 16V ON THE PIP PCB. PART # 181P502060 4. CHECK FOR 7.2V DC ON THE BASE OF Q7003, IF LOW OR MISSING. CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PART # 103P401050 5. SUSPECT R2045/R2048 (6.8 OHM 3W) FOR OPEN/RAISED VALUE. LOCATED ON PCB-SIGNAL AT 5V REGULATOR IC2003 PIN 5.
Nov 21, 2007 | Mitsubishi VS-60611 60" Rear Projection...
Mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Oct 27, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50VA1 schematics or resistor ID
Perform PIP bypass (must give up PIP function) 1)remove PIP module,leave out. 2)Install 22mf/50v NP caps on bottom of PCB. Mount cap to VP pins 5 to 11. " " " " " 7 to 9. Re-check video=should be clean.
Aug 22, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
