Question about Daewoo DSC-30W60N 30" TV
TV Picture Cuts Out
Hello, I have had this Daewoo TV for around 3 years now and have had the problem for probly 2/3 years but it is just getting too frequent and unbearable now. The issue at hand is; everytime I use the "line" function (DVD, XBox, etc.) on the TV, the picture gets dark, flickers, and cuts out on random occasions. If I try to solve this problem by messing with the yellow, white, red cords in the back it makes the problem worse and can cause both the sound and picture to cut out and can take upwards of a half hour to fiddle with to get both back and working for the time being. I can solve the problem by tapping, sometimes hitting with great force, the side of my TV and the picture knocks back into place after a few whaps or shakes. I really want to get this problem fixed as it is driving me crazy. What is the problem and what should I do??? Thanks in advance.
    Problem Solver:
  • 20 Answers
Sounds like you have bad soldier connections inside your set.
Posted on Mar 17, 2008
SOURCE:
I have a philips flatscreen (32PF5331 / 12) that I bought it around 3 years ago. Everytime I turn on the TV, I only get the sound then I should turn the TV on and off (sometimes 5-10 times) before I...
Hello, not positive what part you need...but it sounds like maybe the main board needs replacing. I have purchased parts many times from a company named ShopJimmy.com. I included a link to the part from their site for your model. Hope that helps!
[email protected]
http://www.shopjimmy.com/catalogsearch/result/?q=32PF5331
Aug 25, 2011 | Philips Televison & Video
Our Daewoo LCD DLV-42C7LMB has sound but no picture? We can hear the TV perfectly but the picture is blank completely. We have no Austar and no normal TV stations. We have checked all of the connections...
Chances are you have LED lamps in the panel that are bad and need replacing..look at spending at least $150 to get it repaired, for this TV 3 yrs is longer then they typically last, they aren't exactly high quality sets
Mar 06, 2018 | Daewoo DSC-30W60N 30" TV
We have an old TVwhose picture cuts out every 5mins or so
Not a picture tube problem. Re tune the the TV by auto search or manual tuning.
Store your favorites later in your way.
May 03, 2010 | Televison & Video
Daewoo FR 251 refrigerator cuts off automatically very frequently
CHECK ALL ELECTRICAL CONNECTIONS FROM PLUG TO UNIT.
IS THE COMPRESSOR GETTING VERY HOT, COULD BE LOW ON GAS. THERMO CUT OUT.
IF ITS OLD, ITS TIME TO REPLACE IT.
May 29, 2009 | Refrigerators
It just won't keep running after running fine a while.
PROBLY NOT TRIP CHARGES ARE AT LEAST 45.00 AND THEN 65.00 PER HOUR PLUS PATS WHICH ARE EXORBENT
May 20, 2009 | Mitsubishi VS-55707 TV
Philips 7 year old 32inch cuts off while a high pitched buzzing sound stays until the tv is switched off at the mains
IF PICTURE PULLS ON RIGHT ADJUST BRIGHTNESS AND AND TINT UNTIL SCREEN SHOW FULLY AROUND PICTURE
Apr 04, 2009 | Philips 32PT5441/37 32" TV
Tempermental TV
Hello Sir,
I hope your tv is the power problem or the main board.
But if this the back light problem then you don't need to repair your tv just sale as part (cause this back light part is hard to find and the cost is high).
You need to sent this tv for inspection. any question call me at 323-767-6030
Jan 31, 2008 | Astar LTV-3201 32 in. LCD Television
NO PICTURE
there is a broken conductor strip or broken solder joint on the circuit board near the power input jack. do this: 1.) disconnect tv and open panel to expose circuit board. 2.) using a flashlight and magnifying glass, look carefully for this broken solder strip or solder joint. Flex board slightly if necessary to aid in finding the break. 3.) repair it using solder iron and flux solder and scratch copper conductor slightly to aid in "wetting" the solder fix.
Jun 09, 2007 | Daewoo DTQ-26S1FC 25" TV
Compressed picture in the upper corners of my Daewoo DTQ-20U4SC TV
It sounds like you have a "pin cushion" problem. There is a "pincushion circuit in your set that causes it to make a "square" picture. Some component in this circuit has failed. I am assuming that your set is the "picture tube" type--- not LCD or Plasma. You need to have a tech check it for you. Stargazer
Feb 05, 2007 | Daewoo DTQ-20U4SC 20" TV
Daewoo DSC-30W60N 30" TV Logo
174 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
