Question about Olympus Stylus Verve / ?-mini Digital Camera
Outside shutter cover will not open
Whenever I turn on my Stylus Verve, the shutter door will not open and it beeps twice and then turns off. I can review pictures as long as I turn it on in picture review. I think the motor is shorted and the camera is garbage.
I did try a new and fully charged battery to no avail.
  • 1 more comment
  • Anonymous Aug 15, 2008
    Same problem. After, the camera beep 14 times! Then, shutdown.
  • Anonymous Sep 06, 2008
    my camera
  • lauren101010 Oct 21, 2008
    the lense cover wont open, and it beeps, yet i can still review
With my camera - correcting the shutter position makes no difference. Sometimes, the motor actually is able to move the shutter - but always the camera powers off if not reviewing photos.
Posted on Oct 26, 2008
The only thing I can recommend is to manually push the cover open. But, it will probably stay that way, and not close.
Posted on Jul 01, 2008
Regrding Olympus Stylus 500.. When turned on the lens cover opens half way twice then closes with a green flashing light and beeping sound.
Have just solved similar problem with mine. Problem turned out to be that the lens cover was very slightly dented in. It didn't really look dented at all, but just wasn't quite symmetrical and was a bit more recessed on the side away from the shutter button. This was causing it to rub on the case when it tried to slide. (Mine had been not sliding completely shut for a while before it stopped opening properly too).
To fix it I undid two small cross head screws which let the front panel be prised off. On mine, with the front panel off, the lens and lens cover mechanism all worked perfectly, as the problem was that the lens cover was rubbing on the front panel. If yours is still broken with the front panel removed, then your problem is not the same as mine...
I used a small screwdriver to push out the metal bar on which the top of the lens cover slides, pushing on the right hand end of the bar to slide it left and out through the USB connector compartment door. That lets the top of the cover come off the bar and move freely. To take the cover off, it has to be detached from the arm which moves it. There is a pivot trapped in a slot in the arm, but once the cover is off the bar at the top, it can be moved down so that the pivot reaches the bigger hole at the bottom end of the slot in the arm. This lets the whole lens cover come off the camera.
I then used a screwdriver to gently push out the middle of the cover until its shape was more symmetrical. (I'm not sure a screwdriver was ideal for this, as there are now tiny lumps in the cover where I was pushing it).
Putting it back together was the reverse of taking it apart, although you can test whether it's fixed or not before doing up the screws holding the front panel on.
Apr 28, 2010 | Olympus ? Stylus 500 Digital Camera
Card cover open error message
Hi!
You need to make sure that the memory card is correctly installed on the camera and that its door lock is closed.
Sep 05, 2009 | Olympus Stylus Verve / ?-mini Digital...
Won't connect to computer
happens to me too, is it because im using mac? they dont compatible with anything you know..
May 18, 2009 | Olympus Stylus Verve / ?-mini Digital...
Check card cover- Card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $100.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 26, 2009 | Olympus Stylus Verve / ?-mini Digital...
Problen
The problem you are describing is a problem with a sensor on the card cover or battery cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $93 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Sep 12, 2008 | Olympus Stylus Verve / ?-mini Digital...
Olympus Stylus Powers itself off
the power on button is located under de lens slyding thing, therefore probably is broken or just need to be glued to do that u will need to open the camera. the other u will need to replace a small battery on the mainboard. good luck
Dec 04, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
"Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
May 07, 2006 | Olympus Stylus Verve / ?-mini Digital...
Weatherproof
The Stylus Verve weatherproofing protection is equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus Verve is designed to operate at ambient temperatures of 32?-104?F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and cannot be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Weatherproof
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Olympus Stylus Verve / ?-mini Digital Camera Logo
203 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
