Question about Rival 8210 2 Quart Ice Cream Maker
MOTOR DRIVE DOES NOT TURN
When I plug it up, the motor drive makes a noise like it is on, but it does not turn and drive the shaft. Could it be locked up?
Danny
    New Friend:
I hadn't used my ice cream freezer in several years (6+) & it wouldn't turn when I plugged it in! It hummed, but no turn; so I pressed down on the motor for about 10 seconds & viola! It started turning!!
Posted on Jul 29, 2016
Dear Dannyvk,
I am having exactly the same problem with my rival 8200 ice cream maker. It worked once and stopped usual, when I first used it. The ice cream was wonderful.
However, when I started to make a second batch, the ice cream maker just hummed after I plugged it in. No movement of the pin/hub whatsoever. I tried to move it, by placing the steel can on top and moving it side by side. I plugged it in again, and experienced the same old humming sound.
Is it a fuse? Is the motor blown? Is this something that a small appliance dealer can repair at a reasonable cost? Can anyone help? I am so disappointed!
Faithful in Christ,
D.
Posted on Jun 16, 2008
Motor making loud noise and Shaft not turning Is repair possible
The bearing or bush of the motor would be faulty. try to put some oil on the shaft.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Cuisinart Ice Cream Makers
Will not turn at all just makes humming noise
I had one do that and I opened the gear box and found that the last time we made ice cream & it started getting hard the motor caused the gear to pop a tooth off (plastic). so now you hear the motor running but no transmission. Take it apart and check or turn the ice cream tub connection socket 1/4 turn and see if that makes a difference.
Nov 18, 2015 | Cuisinart Ice Cream Makers
How do you oil/grease the motor?
You don't, this is an electric motor. Oil and lubricants can cause damage to the motor or even cause a fire. If you feel that you need to have the motor serviced take it to a professional electrician who has experience in servicing such motors.
Sep 08, 2014 | Rival 8401-M 4 Quart Ice Cream Maker
Drive shaft stuck
if you can't get it out thru the barrel then you will need to remove the gear box behind the shaft and push it out that way. you should align the shaft afterwards to not rub also make sure your not lubing the bolt pattern on the shaft. after its out use the cleaning brush and clean the coupling.
Mar 02, 2013 | Taylor 794-27 Soft Serve Twin Twist Water...
I have an ice cream maker ice 45u but the mixer blade is not turning. The power is there because i can hear it and when i pull the leaver down the cogs turn on the sprinkler system are turning i have...
Check that all gears are in good working order. The paddlewill not turn properly and the motor will not run if the gears are worn ordamaged gears. Inspect the paddle for damage and replace if necessary. You alsomay need to replace worn or damaged gears in the motor. Lubricate the motor,drive shaft and motor bearings. Hope this will help you. Good Luck.
Sep 03, 2011 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
New motor makes loud noise when operating
Use a food grade grease to lubricate the gears. The newer White Mountain freezers have Chinese made motor drives and are a piece of junk. Don't confuse the newer models with your old American built machines. If it's still under warranty contact the manufacturer for warranty repair. Read the most recent customer reviews for the 4 & 6 quart electric freezers on Amazon and other websites. You will see a rash of motor failures!
Jul 20, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Rival icecream maker
Perhaps some gears are breaking inside the motor? If you need parts, they are sometimes available here: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=rival+ice+cream&submit=Search&_sid=93311479
May 27, 2010 | Rival 8401-M 4 Quart Ice Cream Maker
Ice cream freezer purchased last year and used twice will not run, seems to be froze up
Could have got salt and water in the top of the motor which siezed the motor shaft. If it humms try taking it apart and spray some WD40 on the motor shaft and other shafts
Make sure it is unpluged first!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Aug 09, 2009 | Hamilton Beach 68330 4 Quart Ice Cream...
OUr rival 8550-x 5 quart wooden electric ice cream maker doesn't turn the blade in the canister. The motor is running but the blade doesn't turn in the canister.
take it apart and find the striped gear the motor actualy turns at 2000 rpm and has a reduction unint inside
eithor the gear is striped or the grub screw fell out of the drive gear could also be a drift or sheer pin on the main shaft
Aug 03, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Rival 8210 2 Quart Ice Cream Maker Logo
937 people viewed this question
Top Rival Ice Cream Makers Experts
Dan Webster
Dan Webster
Stan Skaggs
Stan Skaggs
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Rival Ice Cream Maker Expert? Answer questions, earn points and help others
