I need help with a system that I just bought.
First of all, hello to all here-would appreciate help putting together this system.
This past weekend I purchased some stereo equipment from a garage sale---
everything had been disconected-I bought it for $150.I have these:
Denon--dra 335r tuner-----adcom gfa 545 amp--adcom g f 6 spkr selector
Sony cdp cx235 (cd player) ------carver tfm 6cb amp---
I also have a ton of wires that came with it,connectors---Im just worried about maybe sparking up and damaging a piece---I hope someone can help me with this,again thanks to whoever takes the time to help me.Also could it be possible to hook up a surround sound system with this-- I have a kenwood surround system I bought about 6 years ago---Thank you
  • 56 Answers
Well it should be like this...Your amp is prologic which means that it has 5+1 outputs (sub out may be for active sub).Connect your speakers on specific output for each one (center,front left,front right,rear left,rear right and sub).Other devices,CD,tuner...connect to the amp with signal RCA-RCA cabels.On the back of the amp you have all marked inputs.You wasn't specific what do you want to hook?!If you want to hook this "new" to kenwood connect rec out of it to aux in on kenwood.If oposite kenwood rec out to "new" aux in.Hope that this is what you need
Posted on Mar 18, 2008
SOURCE:
Can't get regulator to attach to stove
The regulator is a left handed thread try some grease on the thread might help.
Aug 26, 2014 | Grilling
I bought a Hodedah bed frame over the weekend but when I brought it home and opened the box there weren't any instructions how do I put it together?
You should go back to the store that you bought the bed from and tell them that it didn't come with assembly instructions. If you can't beds are actually pretty easy to put together I recommend checking out this video and some other videos on their channel.
Feb 16, 2014 | Furniture
1993 Montero will not start. Has Clifford alarm and remote start. Started acting up 2 weeks ago and would not start with key, started with remote. Key then started working. Since then problem has occurred...
Hello my name is Israel. I will try to help you out. I would first check to make sure it is not the alarm. You will need to get under the sterring column area and look for a black/yellow wire that is spliced. You will need to connect that wire back together. This black/yellow wire is for the starter. If the alarm is acting up and you spice this wire back together it should start. If the vehicle, after connecting this wire together, does not start then you probably have a starter problem. Hope this helps. Good Luck.
Mar 22, 2010 | 1993 Mitsubishi Montero
Hello i want to take my tracks and make them on to one file
Try to use a program called nero wave editor. What is does is allow you to cut and paste on any wav file. You can inturn just past the one song after the other.
Hope it helps.
Oct 06, 2009 | Fostex MR8-MKII - 8 -Rack Portable Compact...
Dont know how to put the shampoo system together on my kirby g6..
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
May 02, 2009 | Kirby G6 Bagged Upright Vacuum
Cant start my yzf250 2004
check your ground wires to frame . scratch a little to get the neg. side grounded. also motor to frame. clean around bolt heads.
Feb 09, 2009 | 2004 Yamaha YZ 250 F
Throttle cable
I find myself riding home with others and my throttle cable breaks! No power no juice...talk about scary! I am new rider and in 2 weeks have racked up over 800 miles. While impressive the loss of power on the highway was a major scare. I have a 2003 model AutoGlide However the bike did have aftermarket risers put on the handlebars I have my bike being towed to a shop. My question is: What cable part do I need to get for repair because its longer than the standard due to the risers on the bars? Any help would be greatly appreciated, I bought this from great people (private sellers) and I imagine it wore out over time?,You need to make sure that you put a two cable system on the bike. We only have one length of cables. For the pullback risers we route the cables differently. You should contact a Ridley dealer for help with the parts. If you don't know a dealer you may want to get acquainted with the folks at Route 66 Ridley, 414.358.8441,,,
Nov 10, 2008 | 2007 Ridley Auto Glide Chopper
Sanyo Model DP42848 42 inch
I just bought the Sanyo you inquire about and am afraid of this problem. Did you fix it? How do you like your tv? Wish I could help with your issue and appreciate your time, Pogo.
May 31, 2008 | Sanyo DS31520 31" TV
265 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
