Logitech USB Mic/Headset not working with Vista
My Logitech USB mic/headset wont work with Vista yet works on my Windows XP machine. Have done Windows update and so all my drivers are up to date according to MS.
What else can I do. I dont have any Vista installation disk, my PC came with it already installed. There's a yellow ! listed next to the name in Device manager.
  • Anonymous Mar 12, 2008
    May I ask what I should download to fix this problem? Thanks
  • Anonymous Dec 18, 2008
    No Galaxie. It is a VISTA PROBLEM from the most recent Vista update. I think it is clear to everyone now that this is the case. It is the same for me. No one seems to know how to fix this either... This is very annoying and I hate Vista. What a complete flop
I had the same problem until I noticed I was running Vista SP1. Search and download Vista SP2 and you will be good to go
Posted on Jul 13, 2009
This is a vista update and Microsoft is currently working on how to fix it. In the meantime... you can download Windows Vista Service Pack 1 (SP1) manually by going to the below website
http://www.microsoft.com/downloads/details.aspx?FamilyID=B0C7136D-5EBB-413B-89C9-CB3D06D12674&displaylang=en
Microsoft will be hopefully sending this out as an automatic Vista update in the near future.
Hope this fixes you problem
Posted on Dec 18, 2008
No, its not the audio device, as my sound is all working okay otherwise with all other devices. I tried the headset on my friends new HP machine also running Vista and the guess what? same thing happened. So obviously its a Vista problem and not the sound card nor the USB ports. I contacted Maxdata the PC manufacturer and they suggested a hotfix which didnt work (the link didnt work not the hotfix). I emailed them back and they suggested contacting Microsoft which i have done.
Thanks for trying folks, and keep em coming. Any more brainy ideas are more then welcome.
Posted on Mar 25, 2008
Sound all working ok otherwise. I contacted Maxdata (the PC make) for a solution and they suggested contacting Microsoft for a patch or fix. Which I did, and guess what they sent me a hotfix for the problem. AND, would you believe, the hotfix failed on opening. Just my luck!!!! I have emailed the source.
Stangely enough, I tried the same headset on my friend's new PC (which was a HP machine) and guess what? exactly same thing, Logitech headset failed in exactly the same way.
So now we know its not a PC manufacture problem nor is it a sound card problem. Its definitely a Vista problem. Anyway, thanks folks for all your suggestions and keep em coming. Any brainy ideas out there always welcome. Also if and when I find the answer to this problem I will post on here. thanks
  • 35 Answers
If you dont have any installation disk, well just download it from the internet. then install.
Posted on Mar 12, 2008
  • Anonymous Mar 13, 2008
    try to search for the driver of your usb mic/headset on the internet.
    search for it by using its brandname and its model. use google for reference.
Surely the problem is the audio device? Possibly the USB port (but less likely) Drivers for mic/headset? Possibly some software that gives advanced functionality to them but not drivers. A mic/headset plugs into the sound card - if that works so do the mic/headset.
Easy way to test this is to see if you get sound through the PC speaker or connect an external set of speakers. No sound = No sound card installed.
To find the right drivers identify what make and model of PC you have and then go look on the support section of their website for the correct audio drivers.
If it is a HP PC they will even detect the PC model from you directly on the site.
6ya staff
SOURCE:
My mic isnt working but i can hear out of my headset
If you are running Vista, make sure that you set your mic as the default. Then check on vent settings and make sure that your output setting are set for your head set. You can then test your headset inside of the settings tab.
Jan 27, 2010 | Genius HS-04SU Headset
Why wont my headset mic work i can hear through headset but friends cant hear me i have done all checks and all in properly
try using the windows sound recorder in the accessories menu in the all programs menu in start menu
if you are able to record sound on that it means that your mic is fine but the game or software your are using to communicate to your friends doesnt have it selected
if the windows recorder doesnt work with your mic then either the mic is broken or it is not set as the default sound recorder in windows sound settings
Sep 29, 2009 | Electronics - Others
Headset mic won't work.
What have you done to try to fix it I need to know so I can help you fix it and Mabry you need new headsets
Nov 18, 2017 | Logitech (980158) Headset
Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
Mic
Try and redownload the driver.
heres a site youd need to find it if you dont have the cd
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en?selectedcrid=408&selectedcid=221#
Jul 24, 2008 | Logitech USB Desktop Consumer Microphone
My logitech usb headset dnt work
your program is probably set to use the wrong input for the mic, check your settings.
Dec 27, 2007 | Logitech 250 Headset
Microphone not working
maybe its a problem with your sound card. Check your microphone settings in Windows.
Dec 11, 2007 | Altec Lansing Stereo Headset with...
Logitech headset, new vista operating system
either the headset is not supported by Vista, or you need to right click on both speaker icons, normally coloured red and black and in the properties you need to see if your headset is listed as one of the microphone input devices, if you need to make the Logitech headset the default mic and not the windows generic mic. If you do not see it in the properties then it may not be recognised by Vista.
Aug 13, 2007 | Logitech Internet Chat Consumer Headset
Head set problem with vista
you will need to go into the sound manager in control panel and make sure that the external mic is enabled as the default use and ensure in the sound settings that the mic is not muted, this is normally done by right clicking the speaker icon in the taskbar and selecting options and see if the mic is muted or not in the properties
May 26, 2007 | Logitech Premium Stereo Consumer Headset
Open Questions:
CHANGE password on YAHOO email account #{18OO~828O294} phone number usa Anita. There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. Please Read If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Oct 23, 2019 | Yahoo Computers & Internet
Computers & Internet Logo
1,520 people viewed this question
Ekse
Marvin
Marvin
