Question about Toshiba 43H70 43" Rear Projection Television
Help it power`s up the crt`s are lit but no hight voltage, but when i tap the chasses the high voltage comes on and pic is jumpey like a vert proublem need help
  • Toshiba Master
  • 8,617 Answers
Resolder the vertical IC that is whats making the CRTs go blank. Its a safety issue where the CRTs blank when there is no vertical deflection. Just resolder the output IC that should cure your problem
Posted on Mar 12, 2008
Supplied output voltage has hight frequency
Line-load-regulation to the TV power supply board is very low. Replace the main power supply board.
Jan 24, 2013 | Televison & Video
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
NO HIGHT VOLTAGE
sounds like the LSB is defective as that controls all the high voltage and deflection circuits. If you go to the following link and leave them a email with your model number they should have a LSB board for your model.
http://servicemanuals.vstore.ca/
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Help
You have got to have a cold or cracked solder joint. Get a strong light and go over the chassis with a magnifying glass. Solder everything that doesnt look shiny but be looking for hairline cracks in the solder especially near the vertical output IC and associated components.
Mar 12, 2008 | Toshiba 43H70 43" Rear Projection...
Toshiba 43hx70
i dought it, check aroiund the convergence ic's "stk392-xxx"
Feb 08, 2008 | Toshiba 43HX70 43" Rear Projection...
Powers up no pic
You have a bad solder connection in the Vertical deflection circuit. Try re-soldering the vertical output IC and the Vertical yoke pins. You may have to look over the Vertical circuits with a magnifying glass to actually find the bad solder . A hint if the solder looks dull re-solder it.
Jan 23, 2008 | Toshiba 43H70 43" Rear Projection...
Vert hight adjustment
How do I adjust the vertical hight of a SANYO 36" TV. vertical height can adjusted by height conrol that is inside tv in your case you can also adjust by remote control. for that you will have to open menu by giving service code. regards thanks
Sep 10, 2007 | Sanyo AVM-3659S 36" TV
Tosjiba cn32g90 no picture or sound
Timm,What you have Is Vert Failure,Toshiba is Noted for Bad Conns On the Vert Ic,Pull the Back off and Gently tap with a NonConductive Inturment and watch the Sceen Look for Heatsinks and Tap on those,If you know,or you caqn solder do so ,Do run the tv for a long time with no Vert or it will Cause BURN IN in the Phophurus
Jul 15, 2007 | Toshiba CN32G90 TV
Volume buttons stuck inside
hi , first i want to say that the tv is not a game it is hazard set very high voltage inside so if you don't have any experience please dn't try to , but you can do it your self just took outlet off and took case off and try to draw the chasses towards you to behind then look inside to the place of the buttons you will see aplastic tips which will push the volume switches that are soldered on the chasses and with your fingures try to push out the plastic tips to relocate it to the original state it is too easy and the please try to be away from the cable that is fixed to the screen cause high voltage is it, refix chasses and cover and give me high rate insted of £40:) regards
May 06, 2007 | Sanyo DS24425 24" TV
Toshiba 43H70 43" Rear Projection Television Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
