Question about Toshiba 43H70 43" Rear Projection Television
Help still have problem i`ve done what you said and still same thing when i turn it on i can see the guns are lit but no image comes on if i give chasses a tap it come on and bliks like crazy can you help any more? thanks
  • Rob McCutcheon
    Rob McCutcheon Sep 20, 2008
    yes this work for a bit but it ran for a week now back too the same thing again...what can it be this time
    thanks
  • Toshiba Master
  • 8,617 Answers
You have got to have a cold or cracked solder joint. Get a strong light and go over the chassis with a magnifying glass. Solder everything that doesnt look shiny but be looking for hairline cracks in the solder especially near the vertical output IC and associated components.
Posted on Mar 12, 2008
  • Sonny Berry
    Sonny Berry Sep 20, 2008
    Still got to be a solder issue.
SOURCE:
Hi! Thank you for your help. I have a Samsung TV
Hi Doug Rudnik,
First of all thank you for contacting Fixya.com regarding on your TV problem.
You've mentioned that you can hear a sound for 1 sec and then the unit immediately turned off and there's a constant red LED lit. The symptoms you've described indicates that the main board of your unit is working fine and it automatically shuts off because it sensed malfunction on image boards. The constant red LED means that it is on standby mode only.
Now, since you've replaced the power supply board but still the symptoms persist, then the suspect is either the X or Y sustain board but high chance that the fault came from the Y sustain board based on my experienced. Y sustain board is located on the left side of your unit while the X sustain board is on the right side if you are facing the rear cover. These boards has a ceramic fuse(white color) and pico fuse(looks like resistor), please check the continuity of the fuses to determine which board gone to malfunction. If you found an open fuse to Y-sustain board then you need to replaced it. Blown fuse means that the circuitry on its line gone to excessive current.
I would advice you also to inspect the electrolytic capacitors on these boards. Most of the time loud pop came from a blown capacitor and has a physical indication of fault like bulged/dome at the top and can be easily identify through visual inspection. It can give you an idea also which board gone to malfunction. See sample picture below of faulty electrolytic capacitor with bulged dome at the top.
Here's the link for X and Y sustain board.
Y sustain board
X sustain board
Hope I've gave you an idea what's going wrong to your set.
Have a nice day and take care!
Kind Regards,
Jdvillanueva
Dec 06, 2011 | Samsung Televison & Video
My rifle is out, 3"
The gun can be getting hot during your sighting in session. Heat from the reviver can throw your setting off, then as you adjust things get worse. Start and loosen the scope rings one at the time. Front first, and re-tighten, then the rear. Fire 2 shot groups, letting the gun cool some in-between each group. This way you can figure out if it is the scope loosing it's center or the mounts getting in a bind due to heat and twisting the tube. After each adjustment tap on the scope to set the cross hairs, again this will give you feed back, if the scope can hold it's center. Hope this helps Fix Ya up.
May 18, 2011 | Optics
I have a gravity fed latex gun. It worked fine the first couple of uses, but now the spray is in consistent everytime. I,ve cleaned it out thoroughly numerous times and it will spray light followed by...
your air compressor is "cycling". you don't have a consistent pressure on the gun. I had the same thing happen with 2 different Husky paint sprayers....Turns out the sprayers were fine, I just had inconsistent air flow going to them....Turn your air compressor supply line down lower than the tank pressure and see if that does it for ya..........
Dec 17, 2010 | Garden
I have a Mitsubishi HD1080 46 inch TV. The projection shows a concave picture and there are red and green outlines like a 3D image but without the glasses. This problem has come and gone in the past now...
I have the same problem. At first I thought the TV just needed some warming up because after a while it would resolve itself. Now, even after hours of being "resolved" it will occassionally revert back to the concave image! Have you gotten any feedback or resolution?
Oct 19, 2010 | Mitsubishi Televison & Video
PS3: No image or sound.
the power unit probably got damaged also try another tv and look for your proof of purchase you mite still get it replased for free either from the store you bought from or SONY.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
05 Chrysler Crossfire Convertible top
Try using urethane sealant to redo the seal between the top and the glass.
I have a VW convertible that had the same problem. The sealant comes in a tube that you use in a caulk gun. Made by 3M and I purchased it from Advance Auto. About 18 bucks.
Jun 02, 2009 | 2007 Chrysler Crossfire Convertible
Tv duplicate image
your guns are off and need to be adjusted. your 3 guns (red, green and blue) are off and that would explain the funny colors and shadows. Have a tv tech come out and have a look, they can fix it for a reasonable price.
Oct 20, 2008 | Televison & Video
Bent image
Excelent description,whats happening is your set starts to show a blue convergence problem and is only correctable by replacing the blue convergence amplifier IC,the set has 3,one for each color,not all of them develope problems but they all develope loose conections,after the IC has been replaced there are adjustments to do.If you are familiar with tv service this information will give a place to start but if you are not too familar be safe and call a servicer to help you.Lets US know how it goes.
Oct 13, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
