Question about Microwave Ovens
Panel (time,date,Etc.) does not light - Microwave Ovens
  • dgunstone Mar 12, 2008
    You mentioned nothing about repairing this problem and this microwave is only three years old and only used four months out of a year cost $520.00
    Yes please the last person was mof no help at all . The microwave works but the panel light (clock,time, etc) does not light up.
  • 2,336 Answers
It looks like the timer & control may have to be replace or if you are handy with a soldering iron and a multimeter you can check the power supply that powers up the display.
Check this site for some additional info and you can browse through the parts supplier here and enter the model number of your microwave to find the entire timer & control assembly if you decide to change it yourself.
Let me know if you need more assistance.
Good Luck.
Posted on Mar 12, 2008
  • 82 Answers
It sounds like a bad wire connection to the lcd screen which could be fixed with soldering or moving it just right and taping it back so it has connection
  • Microwave Ovens Master
  • 13,433 Answers
Can you still microwave food?
If you cant the device has broken down and I would recommend takeing it to warranty repairs.
If its a cheap model, I supose you might be better off with buying a new one. Since if you dont have warranty repair it might cost more than a new model.
If you need more assistance let me know.
Thanks, remember to review and good luck to you
Just stopped working panel displays time etc but no microwaving going on
  • Open internal fuse
  • Defective magnetron
  • Defective control panel
Jan 29, 2017 | Microwave Ovens
Oven comes ON when closing the door.
Sounds like the control mechanism has lost control.
Disconnect from Power & try & reset Date / Time Etc
Otherwise
Time for a new Microwave
Dec 02, 2015 | Microwave Ovens
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Jan 07, 2015 | LG LMV1630ST Microwave Oven
GE JNM 1851 microwave display panel light is out
The GE Answer Center is telling it like it is. Bet it's touted as a customer-friendly "improvement".
Sep 05, 2017 | GE Microwave Ovens
Ge eterna series - installed above oven. microwave stops working and display instructs to set time and date, then after setting time and date and starting oven again it stops after a few seconds and asks...
The magnetron draws a lot of power and the mains may be dipping beneath an acceptable level, causing the panel to reset.
Check the supply cable size and any connections.
Jan 23, 2011 | GE Microwave Ovens
When machine is first turned on it will run till bin is filled and it cuts off, but will not restart after ice is removed from the bin.This os a hoshizaki commercial ice machine
Remove front panel, look at controler,(where the blinking lights are) there should be a sticker on the back of the panel that tells you what the problem is by how the light flashes. IE- if light flashes 2 times, stps, flashes 2 times,etc, etc
Oct 08, 2010 | Microwave Ovens
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
My GE model JVM1653 has problems when heating I
Take the 2 screws out of the top outside grill. Take the 1 screw out of the top of the control panel. Lift the panel slightly and it will tilt out and hang there. Try a cook cycle with the panel in this position. If it works, your problem is interference from your magnetron. It is very common on these units. I do not recommend adding EMI shielding with tin foil as many have been suggesting on the help sites. If you are still under warranty, call GE. If not, call GE and threaten to sue. This is a known problem with these units and they should have been recalled.
Mar 15, 2009 | GE JVM1653 Microwave Oven
GE Spacemeker Microwave Oven xl1800
The Control Panel is failing. The Control Panel consists of a Keypad, and a Control PC (Printed Citcuit) Board. You can replace it as a complete unit. Not Cheap!!
Good Luck!
Feb 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
