Question about Lexmark X5495 Printer
A plastic strip seems to have out fallen; its the
A thin plastic strip seems to have out fallen; its the length of the printer and small holes on each end.the cartridges keep bangin when it is turned on/off
    New Friend:
It CAN easily be fixed, probably. Just re-thread it through the hole in the sensor on the print head (may be hard to find). Then one end goes onto a fixed rectangular hook, the other end is held in place by a tiny spring. If you have lost the spring then you have a problem.
Posted on Apr 02, 2010
  • Official Brand Answer
  • 3,344 Answers
If it's the transparent strip that fell off from the assembly, it's called the encoder strip. It is, somewhat, related to sending information to the carrier's movement on the carrier shaft or the silver rod accross the printer. I'm afraid that can't easily be fixed. But, it would be better to contact Lexmark for assistance. They may be able to help you with that. Hope I can help more on this.
Posted on Mar 22, 2010
SOURCE:
There was a carriage jam error and a long narrow gray piece with a small hole on either end is now completely out of the machine. Help
Sounds like you are refering to the encoder strip. It is a thin clear piece of plastic with little black lines all the way accross the length of it. The printer has a sensor on it that reads these lines so that the carriage assembly knows where it is inside the machine. It is usually spring loaded on one end of it. Both ends of the encoder strip have a notch on it. One side of the encoder strip hooks onto a fixed mount through one of the notches, the other side hooks onto a spring loaded mount. If it is all the way out the strip needs to be threaded back through the sensor on the back of the carriage assembly(the thing you install the ink cartridges into). Hope that helps a bit. It is a simple problem for a tech to fix but could be more difficult if you are trying to do this without removing any of the covers.
Oct 31, 2009 | HP PSC 2510 All-In-One InkJet Printer
What do I do to resolve Error 5100?
open the printer so you can see the cartridges, if you look what the cartridge is sitting on that is called the cartridge harness, right behind the harness and it runs right through it is a thin code strip, this strip is about a quarter of an inch wide and runs the length of the printer and now you need a small bottle of 99% isopropyl alcohol and a couple of Q tips, now bend the Q tip at the end to 90 degree's and now dip the Q tip into the alcohol, and clean the plastic code strip, be real carefull not to break this or you will be e mailing me like crazy, do the whole strip front and back, move the harness to get it all, when that's done realign the printhead, go to start, to control panel, right click on the printer icon and go to properties, to maintenence to print head alignment and do that, hope this helped and good luck.
Aug 30, 2009 | Canon PIXMA iP1600 Printer
Where is the encoder strip on brother fax machines?
I am familiar wih some inkjet models. The encoder strip would usually be behind the ink cartridge carriage. It is a thin clear plastic strip across the length of the carriage. The ink cartridge housing glides back and forth along the encoder strip.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 25, 2009 | Brother MFC-685cw InkJet Printer
Plastic strip fallen off from the ink slide
You are referring to the encoder strip. They can be reinstalled. They must be threaded through a sensor on the back of the carriage.
The mount at the left side has probably been pulled out of position. If the mount is not sitting properly the strip will be loose and will cause problems. The tension mount has two flanges that must be behind the plate it is mounted on. Good luck.
Jun 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Cartridge banging on the right & left walls
There is a thin plastic strip that has small lines on it that stretches across the inside of the printer and fits trough the back of the print head. It is not in the slot of the print head or missing. I fixed my banging Dell 810 printer by putting it back in. I had no idea what it was at first. That's all I can tell ya.
Feb 03, 2009 | Dell 810 All-In-One InkJet Printer
MY cartridge went haywire today
on the left side inside the chassi there is a small hole with a little metalpart sticking up (about 0.5cm high). On the piece where the inc cartrigde is there is a vertical hole you can see the hole easiest from the left side (about 1cm high). On the right side there should be a 2cm metallic part sticking up from the bottom.
You will probably have to bend one of the parts to get the plastic strip on place, just make sure that once you get it on place to bend them back so that the strip doesn't fall off again.
in my case the metallic parts where bent like: \ (left) and | (right) I had to bend them | and | to get the strip on place and then bend them \ and /. Not sure if the right part should be / or | though.
Jul 12, 2008 | Lexmark X2470 All-In-One InkJet Printer
Plastic strip fell off
Hi, if you open the open the printer, unit to gain access to install ink cartridge, if you see the metallic end which has got a hook on both the ends left and right side. the ink cartridge runs between the strip from left to right which should be connected above the ink cartridge meta rod.
< ------------- >metal hooks on left and right above the cartridge rod
======= __ cartridge rod
Let me know for further info.
Feb 05, 2008 | Dell 810 All-In-One InkJet Printer
Canon pixma ip1800
this strip feeds through the back of the carriage and tells the printer where the cariage is so it can tell how far along the page it is. it shuold be quite simple to hook it back on though many ayre spring loaded, if so this means a strip down of all exterior parts so that you can release the spring Hope this helps Cops
Oct 08, 2007 | Canon PIXMA iP1800 InkJet Photo Printer
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark X5495 Printer Logo
114 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
