Question about Maytag MMV5165 Microwave Oven
Microwave not functioning
Have a three year old above range micro wave. All has been working well. Suddenly, it has no power. The wall outlet is working fine since we tested it with a hair dryer. I looked to see if microwave has a fuse but did not see one in manual or in it.
  • Maytag Master
  • 9,098 Answers
The fuse is usually located behind the control panel, sometimes near the switches, or on the chassis floor. In some models it may be mounted in the line noise filter.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 17, 2008
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
    you mean it want power up or want work when you press the star buttom?
    1. check the fuse if no power.
    2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
    3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
    Oct 30, 2010 | Emerson Microwave Ovens
    How do i remove an old oven
    It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
    1. make a landing site to the side, to protect the floor when putting the micro down after removal.
    2. Disconnect the power cord in the cabinet above.
    3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
    4. tilt the front down. pull the cord out of the upper cabinet.
    5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
    6. remove the fasteners in the wall plate and remove.
    Congrats, begin celebration.
    Jul 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    How do I remove my ge jvm 1653 microwave?
    Clean out the cabinet above the micro wave and you will find 2 or 3 bolts that secure the unit (MW) to the bottom of the cabinet. They will normally be towards the front of the cabinet.
    I always put a towel or cardboard over the surface of the range for protection and a place to set the MW once it is ready to come down.
    Have someone either hold the MW up by putting pressure upwards on the front of the MW or take the screws out. (don't forget to unplug the MW)
    Gently let the front of the MW fall forward about 6" to 8" and lift the back of the MW upwards and it will release from a mount that is attached to the wall.
    You may feel a little resistance as it might be duct taped to the exhaust going up or out the back.
    Be aware that these older micro waves can be a little heavy and it is recommended that 2 people are used to do this.
    Apr 09, 2010 | GE JVM1653 Microwave Oven
    Need to replace handle on micro wave can not
    I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
    Dec 18, 2009 | Jenn-Air M439 Microwave Oven
    I have a built in Whirlpool Micro Wave oven that quit
    if you open the cupboard door above the microwave you should see two or four screws/bolts holding the microwave up there. there should also be an electrical outlet up there where the microwave is plugged in. have at least two strong people. put some blankets on your stove top to protect it. unplug and remove the screws. it should be connected in back by a metal plate also. when the microwave is tilted down at a fourty five degree angle, you can give a little lift and it should pop off the plate in back. it is heavy. get a new one at sears or other appliance retail outlets. i dont recommend best buy. they really screwed me over so i dont send business their way.
    Oct 20, 2009 | Microwave Ovens
    The carbon monoxide detector beeps when I run the microwave.
    uplug the micro wave for the same amout of time the dector go off and see what happen if it goes off check the battery and replace them and do the same as above test to see if dector is not working properly
    Jul 01, 2009 | Panasonic NN-T990SA Microwave Oven
    My Maytag MMV1153BA Over The Range Micro suddenly lost power.
    problem is a blow fuse inside the microwave, you need to call a appliance repair tech
    Jun 28, 2009 | Maytag MMV1153A Microwave Oven
    Microwave installation under cabinet, no rear wall
    Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
    Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Maytag MMV5165 Microwave Oven Logo
    110 people viewed this question
    Top Maytag Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
