Faulty TV, no picture but sound present
Have a Hisense Firstline FS3201MHI LCD TV with a faulty TOKO inverter board, that has a cremated 4511GH component.
Anyone help?
Sorry can't solve the problem... yet. But I have exactly the same problem with the same TV. Sound but no pic, and a toko inverter board that has four 4511GH components that look like they have been getting too hot. I get a ticking noise from the power board when it is running, and that dissapears if I run it without the inverter board attached. Did you get anywhere with the fix? I am not an expert so don't know if it is as simple as replacing these four components althogh its the one between CN6 and CN7 that looks worst. Any help?
Thanks.
Posted on Jun 18, 2009
How do i do factory reset on hisense tv ive gotsound but no picture i tried a hard reset i cant watch movies either
Should have worked after the hard reset. Your problem could be with the leds or the inverter board. Do the flashlight test.
May 06, 2017 | Hisense Televison & Video
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
Jan 13, 2016 | Hisense Refurbished 50"" 1080p LED-LCD...
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
Black screen but i do have sound
HelloCheck the backlight inverter board. If it has damged, most common fault to LCD TVs, there will be no backlight to the LCD screen, and will look black. Your tV has sound output without picture. This means that all other boards ar functioning well. Check the backlight inverter section and CCFL tubes used in backlight assembly. OK.
Dec 20, 2011 | Hisense TL1700 17 in. LCD Television
What does it mean when the picture goes out?
Hello
There are so many reasons for picture to gets out. The first amoung them, is of its backlight itself. If the backlight CCFL tubes wont light up, there will be no backlight to illuminate the picture. If baclkight inverter board has damaged, backlight CCFL lamps won't light up. The most common fault with LCD TVs are backlight failure itself. The second one is of with its main video processor board. In short, main board itself. You have to check and make sure which one is faulty. You must ahve sound knoledge in electronics to proceed. OK.
Dec 18, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
The picture went "dark" but
This is an indication that the backlight of your unit is not working properly. This is caused by faulty either in the power supply board or the inverter board. You have to check the output voltage of the power supply board feeding the inverter board, if present replaced the inverter board. If not, check the power supply board for leaky electrolytic capacitor or replaced the entire power supply board.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Sep 04, 2011 | Toshiba 14VL44G 14 in EDTVReady LCD TV
My protron tv pltv-32c has no picture but has sound, if you change channels the picture will flash on for about 1 second
Hi.
If there is sound but no picture, screen is completely dark and the picture is occasionally flashing, then the fault is likely a faulty inverter. In some case a faulty controller board or a defective PSU can cause the same problem.
I summarized the problem here:My LCD TV has sound but no picture.
I posted general procedure to test inverter, PSU and controller board on LCD here : How to test an LCD TV or monitor PSU and inverter.
If screen is not dark, but has blacklight or noise things are different. In that case check connection cables first. Parts that may be defective are main controller board, terminal circuit and tuner board.
Protron parts are available using the link below. Ensure that parts are compatible with your model before purchasing.
ShopJimmy - Protron Parts.
Regards.
May 15, 2010 | Televison & Video
Sound is clear but no picture
Ur LCD inverter board is dead.Replaced this LCD inverter board will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter for the replacement.It a long board in shape.
May 04, 2010 | Vizio L32 32 in. LCD HDTV
Has sound and no picture
Hi.
Ensure you have alredy disconnected power and left TV not connected for at least one hour.
If it is a rear projection model it can be a problem with optical group, video or ballast board. In this TV however this problem is not common, usually the TV goes in standby.
On LCD the problem is often caused by a faulty inverter, in some case bad controller board or PSU with no volt on inverter line to controller board (higher DC voltage). In some LCD inverter is on same board with PSU. Most common is inverter.
Read more on LCD here:My LCD TV has sound but no picture.
Dec 16, 2009 | Televison & Video
Hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
Dec 23, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
430 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
