Question about Canon PIXMA iP90 Mobile Printer
Canon pixma ip90 printer
Service error 5c00 - when i try to print, it fails and display this error report "serice error 5c00". i can't seem to figure this out.
help please
  • 6 more comments
  • crigg657 Apr 12, 2008
    i cant do anything with my printer.the green light will flash green and yellow.then i get the error 5c00
  • gazforsh May 22, 2008
    yes same here, error 5c00 and amber light flashes 4 times. Please help.
  • Anonymous May 27, 2008
    i have same problem ,, message display 5C00
    help please
    thank you
  • bobdabldr May 29, 2008
    Me too. Is anyone else using Vista? And did you get the latest update from MS on the night before it quit?
  • bobdabldr Aug 19, 2008
    Has anyone ever successfully resolved this issue?
  • corpsp Dec 01, 2008
  • bobdabldr Dec 13, 2008
    I gave up on it. Very frustrating. I might send it in for service at some point.
  • Anonymous Mar 20, 2009
    same problem, flashing green and red light and not responding.... Whats the story?????
    Problem Solver:
If your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Posted on Dec 13, 2008
I disassembly the printer; and half way I found a piece of plastic the one that holds price labels on pants and a rip piece of paper stuck inside. pull it out and fix the problem.
now it makes a funy noise, but prints
Posted on Mar 01, 2009
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
The fax appears to dial the number successfully. The receiving fax is turned on. It apprears to try for a long time. The error report says "no answer."
It is not your fax line is the other party.did you try any other number?
Post back.
Solution one: Perform a fax line test Perform a fax line test to check whether the fax line is properly connected. Step one: Run a Fax Test
  1. Press the Setup button (c01395353.jpg ) on the product control panel.
  2. Use the Arrow keys (c01073166.jpg ) to select Service , select Fax Service , select Run Fax Test , and then press OK . The Fax Test prints.
    • If the report passes, try to resend the fax.
    • If the report fails with the message 'Fail - the phone line is not active,' plug the cable into a working telephone jack, and then try to resend the fax.
    • If the report fails with the message 'Fail - the cord is in the wrong port,' continue to 'Step two: Change the cable to the correct port.'
Step two: Change the cable to the correct port Make sure the telephone cable is inserted in the correct port. Remove the cord for the fax line from the port labeled with a telephone, and then insert it into the correct port. Figure 1: Fax portsc01756259.gif Scanner error message The message 'Scanner error ' displays on the product control panel while sending a fax. Solution: Check paper size This product only supports paper less than 381 mm (15 in). Use only letter, A4, or legal sized paper for sending faxes. To send this fax, copy or print the original document onto shorter paper, and then resend.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | HP Laserjet M1319F Laser Multifunction...
Error 5C00 results when trying to print
[5C00} & Light Blinking 4 times = Purge Cam Sensor Error. That's mean there is an error occurred in the purge unit. You may either need to replace PURGE UNIT or LOGIC BOARD to solve out this error. Thank you.
May 28, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Jul 21, 2009 | Canon PIXMA iP90 InkJet Printer
Canon i455 printer displays canon service error 5C00
paper mechanism is vey suspect - time for a new one
Jul 18, 2009 | Canon BubleJet i965 InkJet Printer
Canon ip3000 shows service error 5c00
5C00 is Purge unit error.Check for object around the purge unit.
Feb 23, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
MY PRINTER
i AM GETTING 5C00 ERROR
Aug 27, 2008 | Canon i80 InkJet Printer
Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Error Message appear when printin
It is almost two years i started using this printer but recently whenever i;m printing with this printer, i get a report; " Cam Platten Error" and my document fails to print. Please help me.
Mar 15, 2008 | Hi-Touch Imaging Technologies HiTi 730PS...
Canon PIXMA iP90 Mobile Printer Logo
1,130 people viewed this question
old marine
old marine
