Question about Microsoft Xbox 360 Console
Goin crazy my phone cord goes into a slot labeled dsl and that box has 4 slots labeled e1 e2 e3 e4. that box is wireless . it is connected to another box thats wireless it has 4 slots labeled 1 2 3 4. which one do i connect to and i have verizon is that a good internet connection provider
    Problem Solver:
  • 6 Answers
Well please explain more clearly your connection so i can help you better. and about your verizon... it depends what type of verizon connection you have and i belive you said you have DSL. if you are trying to play games such as Gears of War where there is a large reliance on the host's connection you will definitly want a faster connection such as broadband or the new verizon FIOS which will alow you to support all of the players in your game without a large amount of lag factoring into the game play. and nobody likes a laggy connection.
Posted on Mar 12, 2008
SOURCE:
Bravos X. How can I correct error codes F5 E1, F5 E2, and F5 E3?
remove the relimates/connectors and clean with CTC and refix the same or check the pressure sensor connection , replace the pressure sensor and see
Feb 11, 2016 | Maytag Washing Machines
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Spirio wide 410
E1 -exposure lamp abnormal
E2-fusing thermofuse open
E3-hot roller thermistor open
E4 -hot roller thermistor short
E5- pressure roller thermistor open
E9- pressure roller thermistor short
E7 -fusing overheat
To reset accesing SP 41 and changing the date from 1 to 0 must be done to clear these service call condition.
Dec 23, 2013 | Ricoh Office Equipment & Supplies
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Error codes E1 to E5
E1: tape end detection LED open
E2: front loading motor lock
E3: loading motor lock
E4: cylinder motor lock
E5: reel motor lock
These are from a Panasonic AG-7500 service manual.
Mar 04, 2010 | Panasonic Televison & Video
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Cannot solve game 100 on Professor Layton & the curious village
imagine the dots as a complete grid A-F across the top and 1-6 down the side now join the dots like so A1-B1,B1-B2,B2-A2,A2-A1///C1-E2,E2-D4,D4-B3,B3-C1///D1-F4,F4-C6,C6-A3,A3-D1///
E1-F2,F2-E3,E3-D2,D2-E1///C2-F3,F3-E6,E6-B2,B5-C2///D3-E4,E4-D5,D5-C4,C4-D3///
you should have only 4 dots left to join,good luck
Nov 26, 2008 | Nintendo Professor Layton & the Curious...
Speed 2
it does not matter but if all of a sudden it is not workig use E4
Mar 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
