My HP Deskjet F4140 won't scan
SOURCE: My HP Deskjet F4140 All-in-One
If you are trying to scan using the "scan" button on the deskjet, open your control panel from the start menu on your pc. Go to devices and printers. Find your deskjet on the list, and choose scan.
SOURCE: HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
SOURCE: my hp deskjet f4140 will
same thing happened to me: try this fix
1. open HP photosmart essentials
2. go to the 'get images' blue box location on the view tab
3. click 'from scanner'
4. follow the directions
hope this helps - the printer isn't as useless as i first thought.
cheers.
SOURCE: My HP Deskjet F4140 All-in-One won't scan.
You need to have the printer in the ready state
Just do onething ....... take out both the cart and then insert just one cart and try ... check with only color or back one in the pinter
SOURCE: hp deskjet f4140 wont scan button just blinks
You will have to reinstall the printer/scanner drivers (check on the internet for your type/model and download the drivers if you can't find the original install cd). Usually the HP website is your best bet for old or new driver sets. Source(s): http://h10025.www1.hp.com/ewfrf/wc/produ? Hope it works.
