Question about Canon LaserCLASS Fax 710 Printer
Lines on paper
When I fax or copy I have lines on the sides of the paper
    Scholar:
  • 130 Answers
Clean the scanner glass. pay attension to the area of the glass in comparison the the location of the lines
Posted on Jun 11, 2008
Line appears down right side of paper when copy is made?
If the line only appears when making copies but recieved faxes come out ok, then the scanner glass needs to be cleaned. Water and a lint free cloth should do the trick.
Sep 15, 2010 | HP 1010 Plain Paper Inkjet Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Faxing up or down
Look at the hopper. It will almost certainly have a little graphic on it to tell you which way up the document goes.
If it looks like a sheet of paper with lines of writing on, the paper goes in print side up.
If it looks like a sheet of paper with one corner folded over, and lines of writing visible only on the turned over corner, then it goes in print side down.
If you can't find the graphic, then experiment: Take a blank sheet of paper. Write "Up" on one side and "Down" on the other then stick it into the machine so the writing is telling the truth. Most fax machines have a copy mode - use this to see which side of the paper the machine reads (if you can't get it to copy, fax your page to somebody and get them to phone back to tell you which side of the page they've received).
A.
Jan 18, 2009 | Brother Office Equipment & Supplies
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Canon LaserCLASS Fax 710 Printer Logo
old marine
old marine
