Question about Andis 01690 Hair Trimmer
T-Outliner has stop cutting!
I was using them the other day and they jus stop cutting! I clean them properly! The blade still vibrates but still not cutting! Help!
  • Anonymous May 31, 2008
    i have the outliner 2 and replaced the blade with the t- outliner and it isnt as sharp when im edgin up as other t outliner blades ive used.
  • 61 Answers
Good advice but the best way to align is to know the exact aliment,pay attention to how the blades are set in relation to one another when they cut correctly,and remember this so that next time wont take so long to adjust the blades.
Posted on Jan 26, 2009
    Scholar:
  • 79 Answers
The stationary part of the cutter is held in place by screws. Try loosening the screws and moving this part slightly left or right. This will change the alignment between it and the moving cutter. Once you see the alignment change, tighten the screws and test. You may have to repeat this process till you get the correct alignment.
Posted on Mar 15, 2008
My saw stops rotating during cutting
does the motor stop? If not the gears are worn between armature and spindle. If it does stop you could be applying too much pressure trying to cut with a blunt blade or there is an armature fault.
Apr 24, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Vibration coming from cutting blade through the machine Stihl hl75k
Do you have bent blades.? Try removing the 'driveshaft' and adding a coating of grease, the shafts can become dry within a plastic liner and start to vibrate
Apr 21, 2014 | Stihl Garden
Band saw cutting problems
Make sure that the blade is properly tracked and tensioned, installed. Hope this blog will help you too. http://bandsawblog.com/variable-pitch-band-saw-blades-when-is-it-used/ . Variable pitch blade is a tooth design that combines more than one tooth pitch to reduce chatter and vibration .
Feb 15, 2013 | Saws
Honda HR215 hits stump - still runs and cuts but engine vibrates when running IF the BLADE IS NOT TURNING.
you could have bent the blade or the crank look at the blade then remove the blade mount and spark plug turn on its side and turn the engine over and look for crankshaft runout
Apr 07, 2012 | Garden
Clippers have suddenly stopped cutting and seem to pull at the hair
Generally removing the two screws.. on the blade foot (don't do this over the sink unless the drain is closed!).. and taking the blade apart.. cleaning the trimmers with a small brush.. apply grease in the blade groove.. reassemble
Usually it's best to put those two screws back just get them in lose.. not quite snug..set the blade upside down on a flat surface..so it pushes the blade back away from the cutting end..level..then tighten those screws while you are pushing or holding down on the clippers cutting edge against the flat surface/table. ... oil the blade with the proper oil or a light mineral oil.
This usually will get them back to cutting properly..the blade should be oiled prior to each use...about two to three drops right along the visible part..or a light spray also hair should be clean.. dirty hair does not cut well at all..and the clippers will tug and pull rather than cut cleanly.
Lastly..if they see a lot of use. might be blade replacement time..
Best of luck!
Apr 13, 2011 | Oster 76076-010 Hair Trimmer
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
Craftsman 19.5hp 42'' deck lawn tractor with vibration only when the cutting blades are engaged.I have changed the blades but the the tractor still vibrates alittle. when I disengage the blades the...
Check your spindles, especially the shafts in the spindles. If one of them is bent, it'll make the blades vibrate as they spin. You can find replacement shafts and spindles at Partsbuggy.com.
Dec 18, 2010 | Garden
This thing vibrates so much that I can't feel where the saw begins or ends in my hands. It is new!!! Do all these things vibrate so much? I can only use it at about half speed or it slips out of my hands.
For the most part they do vibrate, that's why it is good to make use of the blade guard when cutting. It cuts back on the vibration. I have hand to use a saw without having that guard against what I was cutting and I thought I was going to have my arm fall off. You may want to check to see that the blade and that part the blade goes into are nice and tight. I've used many saws on different jobs, the best brand of saw for the vibration standpoint that I've found is Craftsman.
May 13, 2010 | Makita JR3050T Recipro Saw 9 Amp
Blade misalignment
The 1590, like several Bosch jigsaws, has a selector switch to choose the type of cutting action. You have to choose the appropriate cutting action, either straight or oscillating, to accommodate the material you cut and the blade you cut with. For instance, if using a very slender blade for clean curved cuts in wood, a slight oscillating motion ( setting II or III) reduces friction on the blade.
If you choose the straight cutting action you get maximum accuracy, but drastically increase the friction because the blade is held firmly to the roller bearing.  A slender blade can handle that for brief periods, (say... less than thirty seconds) in soft, thin wood with a straight cut. In hard woods or engineered wood products ( plywood, MDF etc.) the thin blade will heat up and bend.
You can reduce friction by choosing an oscillating cutting motion, or you can use a larger, sturdier blade. The "Aggressor" blades do not cut as smoothly as the "clean" blades, but they cut faster and are stronger. To cut thick wood ( 4x4 ) or a long cut in engineered material, that is the blade I use. Select number III or number II for 'type-of-cut' and use a bigger blade. See if that stops the "bucking."
Mar 24, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Andis 01690 Hair Trimmer Logo
1,394 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
