Canon PIXMA MX700 All-In-One InkJet Printer Logo
Posted on Mar 22, 2010
Will not print. Paper runs through but does not print. I can copy and scan.
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 46 Answers
  • Posted on Mar 23, 2010
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
46
Questions
0
Helped
17875
Points
77
Http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
The first tip on this site should clear out the nozzles. Using warm water seems to flush the nozzles out better.
Copy Machine is running ready but can't print and copy.
The paper tray is not placed properly leading to erroneous sensing place the paper trays properly
1helpful
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
I can not copy from glass scanner of HP L 7680 all in one, when I load paper into the lid then press copy, printer just load paper in ADF not run copy from glass scanner
Is your system on? If it is on, then you press copy, it scans it and a window showing your scanned document is displayed. Then from here (the system) you can print it. Try it and tell me what happens.
1helpful
Well I have a HP deskjet 2050 print scan copy, printer but for some reason instead of scanning a paper and sending to my computer, it just prints it out. I dont know how to make it work! Please help!
well I have a HP deskjet 2050 print scan copy, printer but for some reason instead of scanning a paper and sending to my computer, it just prints it out. I dont know how to make it work! Please help!
Can't print but it will scan You can copy and scan from this printer but it will not print from computer command
Based on the information you shared:
Did the printer run out of Ink or Paper? What is the error you get when printing. Was it printing before?
If not then you need to install the printer drivers prior to printing.
Paper that was scanned is still in memory and won't stop printing
The Canon PC1061 never had a memory so I can only suspect that you have a component failure. Now try this. Place a brand new package of paper into your photocopier's paper tray. Now also lay one blank sheet of paper on the glass and run 10 copies of it. If you notice that the image that you saw before is getting lighter and lighter then most likely you just need to replace the drum unit (drum cartridge).
I put in the paper push scan push start and it just says sleep nothing happens
you need to have mfc connected to computer with scan software running in order to scan, if you want to copy you just press copy and it will scan and print without computer connected.
2answers
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must
also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To save a scan to a memory card
1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One.
2. Load your original print side down in the right front corner of the glass.
3. Press the Scan Menu button.
4. Press to highlight Scan to Memory Card, and then press OK.
The HP All-in-One scans the image and saves the file to the memory card in the JPEG format.
To scan a photo and reprint it
1. Press Reprints.
2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following:
To reprint your original photo using the default print settings
➔ Press Print Photos.
To change print settings before reprinting your original photo
a. Press OK.
Basics Guide 13
HP All-in-One overview
b. Press or to highlight a paper size, and then press OK.
The paper size choices available vary depending on your country/region.
Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages.
c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK.
The HP All-in-One scans your original and shows a preview of the photo on the display.
d. Press OK to display the selection menu.
Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies.
If you want to edit the photo before printing, press to highlight Edit
Photo, and then press OK.
e. Press to highlight Done, and then press OK.
The Print Summary screen appears.
f. Press or to highlight one of the following options, and then press OK.
Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and
time stamp on your photo.
By default, the Paper Type is set to Automatic and the
Date Stamp setting is set to Off. If you want, you can
change the defaults of these settings with the Set New
Defaults option.
Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and
wasting paper and ink on potential mistakes.
Print Now Prints your photo with the size and layout you selected.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Scan Menu.
3. Press to highlight Scan to Computer, and then press OK.
4. If the HP All-in-One is connected to one or more computers on a network, do the following:
a. Press OK to select Select Computer.
A list of the computers connected to the HP All-in-One appears on the display.
Note The Select Computer menu might list computers with a USB
connection in addition to those connected through the network.
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
2answers
3050
when we copy or scan we get lines at both side throught
the paper
old marine
old marine
ZJ Limited
ZJ Limited
