Question about Canon Pixma MP500 All-In-One InkJet Printer
Feed problem The printer got jammed and I removed the paper but now the feeder is not working on either side. Is there a way to adjust the feeder?
  • colmaj Mar 19, 2008
    When I try to print a document, 1/4 of the paper feeds into the
    printer and
    then the LCD displays an error message that reads, "Auto Sheet
    Feeder -
    There is no Paper - Load Paper and press OK." The Paper Feeder had
    about 20 sheets of paper in it when that error displayed. I pulled the
    sheet of paper that got stuck out of the printer, pressed OK and the
    same
    thing happens again to another sheet of paper. It seems that the auto
    sheet feeder does not recognize the paper loaded in it and then when it
    goes to load, it gets jammed. It is easy to pull right out as it only
    goes into the printer about 3 inches.
    I sent an email to Canon regarding this problem and they suggested cleaning the printer feed rollers. I performed this functions numerous times but the paper still gets stuck and will not load into the printer.
    Any advice will be appreciated.
    Genius:
  • 2,785 Answers
Dear colmaj
your printer paper sensor is strucked or malfunctioned.please open the printer and check for any dislocation of the sensor.or you send your printer for service
Posted on Apr 08, 2008
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
    Follow the steps:
    •1
    Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
    •2
    Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
    •3
    Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
    •4
    Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
    •5
    Print your documents as needed.
    Paper Cassette :
    •1
    Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
    •2
    Pull on the cassette on the bottom of the printer to slide it out of the printer.
    •3
    Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
    •4
    Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
    •5
    Slide the cassette back into the bottom of the printer. The printer is ready for printing.
    Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
    My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
    Hello.
    You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
    Sheet Feeder or Manual Feed Slot: Press the
    paper button to eject any jammed sheets, then open
    the printer cover and remove any paper jammed inside.
    Press the paper button again to clear the error.
    Hope this helps.
    May 31, 2010 | Office Equipment & Supplies
    Cannon pixma ip 4600 error code 5700 - paper jam
    The error code 5700 is the sensor error.Replace the sheet
    feed unit and then adjust the timing of the paper feed gears.
    Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
    Document Feeder jams
    I got adventurous and removed the screws holding the document feeder. I then used a can of air and blew into the gears and then reassembled the feeder. It works perfectly.
    Feb 05, 2009 | Brother MFC-7820N Laser Printer
    Paper jam epson stylus 5400
    1. Turn the printer off and open the access cover.
    2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
    3. Turn the printer on, load some paper, and press the Form Feed button.
    4. Watch the paper as it feeds through and try to determine where the jam is occurring.
    5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
    6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
    7. Turn the printer off.
    8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
    9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
    Dec 08, 2008 | Epson Stylus CX5400 All-In-One InkJet...
    Paper feed on Canon i 350n ink jet printer
    If the paper is lodged too far into the printer and can't be removed:
    Press the power button to turn the printer off.
    Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    Close the front cover.
    Press the power button to turn the printer back on.
    Resend your document to print.
    Ensure that:
    The paper is a recommended paper for inkjet printers.
    You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    The printer is on a flat, level surface.
    The left paper guide is against the side of the paper.
    You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    The left paper guide does not cause the paper to bend in the sheet feeder.
    Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    Envelopes or the appropriate specialty papers are selected in the printer driver.
    You are using a paper or envelope size supported by your printer.
    May 13, 2008 | Canon i350 InkJet Printer
    False paper jam
    Ensure that:
    Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
    Paper jam
    Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
    Ensure that:
    Mar 24, 2008 | Office Equipment & Supplies
    Document feeder works for printing but not for scanning
    Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
    Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    Canon Pixma MP500 All-In-One InkJet Printer Logo
    121 people viewed this question
    old marine
    old marine
